basic stamp 2 — Parallax Forums
basic stamp 2
edited 2004-01-08 23:08 in General Discussion
i was recently in a robotics class, where i learned some basic stuff
about robotics. I was able to build a robot, using a basic stamp 2
chip. A few weeks later, the chip stopped responidng, and i have no
idea why. If someone knows any solutions to this please e-mail me at
eric.drucker@l...
    edited 2000-11-01 23:33
    I am trying to writ a program that will control the firing angle of a
    triac in a dimmer circuit. In the following program I can control
    the intensity of the light by changing alpha and running the program
    again. How do I make a loop that will automatically change alpha from
    0 to 6. Any help would be appreciated.
    input 10
    alpha var byte
    cnt var byte
    alpha=4
    Hold: if IN10 = 0 then Hold
    cnt=0
    bob:cnt=cnt+1
    if cnt >= alpha then ryan
    if cnt < alpha then bob
    ryan: PulsOut 8,10
    pause 7
    PulsOut 8,10
    goto Hold
    Josh
    edited 2000-11-02 05:25
    >input 10
    >alpha var byte
    >cnt var byte
    >alpha=4 <== Why 4 ??
    For alpha = 0 to 6 <== Add
    >cnt=0
    >bob:cnt=cnt+1
    >ryan: PulsOut 8,10
    >pause 7
    >PulsOut 8,10
    >goto Hold
    Next <== Add
    >Thanks,
    >Josh
    edited 2002-02-27 02:50
    I got my Boe-bot to run with programs that I write. I need some to
    tell what is the best way to control the Boe-bot wireless (im able
    now to control it through the serial port ) For example if I press
    the L key on my keyboard it is going left and R it goes right there
    etc. Please help me out. Need this to continue my project.
    Much appreciated!!!!!
    Dave
    edited 2002-02-27 03:29
    Me... I would use the Parallax keychain trnasmitter and receiver. It
    has five signals that you can use to do things. Easy to hook up and it
    works. You can also get transmitters and receivers that use the serial I/O
    methods too, but the keychain model is pretty neat.
    From: ioa_windsor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mwfJTgw0TeVqpVRvpwVGEHLV6Tx4V4xhQLX3bmR-LbbtsZ91c1c_yWNjLxrpGcs6p4HqiORP9iUIl9Ny]ioa_windsor@y...[/url
    Sent: Tuesday, February 26, 2002 8:50 PM
    Subject: [noparse][[/noparse]basicstamps] Basic stamp 2
    Dave
    edited 2002-02-27 03:45
    hey,
    I need to know how to send more than one command at once. As of now,
    i send a command and I have to wait till it stops (beeps) and then i
    can send another command. What i want to do is, lets say i press the
    F button which tells the robot to go forward, I want to be able to
    make it turn left or right while its still going...
    please help...
    --- In basicstamps@y..., "Earl Bollinger" <earlwbollinger@a...>
    It
    and it
    serial I/O
    > From: ioa_windsor [noparse][[/noparse]mailto:ioa_windsor@y...]
    > To: basicstamps@y...
    > Hi,
    there
    > Dave
    > basicstamps-unsubscribe@y...
    Subject and
    edited 2002-02-27 03:53
    You would need to do something like a Loop and check to see what the
    command is. Your in a loop and you use a polling method to see if you
    have received a command. It would work off the serial port as well from your
    PC too.
    Sort of like this:
    Assuming the keychain transmitter/receiver setup.
    Pin1 forward command
    pin2 reverse command
    pin3 right
    pin4 left
    pin5 stop
    MainLoop:
    check to see if pin1 is low goto forward
    check to see if pin2 is low goto reverse
    check to see if pin3 is low goto rightturn
    check to see if pin4 is low goto leftturn
    check to see if pin5 is low goto stoprobot
    Goto MainLoop
    forward:
    make robot go forward
    goto mainloop:
    reverse:
    make robot go backwards
    goto mainloop
    et cetera
    From: ioa_windsor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AYJuwTLlMLlYqDyf7tgZ7DrXm3PpV3PNWJWe3XN_9Cbrtoi2ajBqw0ULmLbdDkHNbi_ZNCK3io1SlJ4]ioa_windsor@y...[/url
    Sent: Tuesday, February 26, 2002 9:45 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Basic stamp 2
    hey,
    please help...
    It
    and it
    serial I/O
    > Hi,
    there
    > Dave
    Subject and
    edited 2002-02-27 04:22
    hi, we are using somewhat of a different program. We kinda got lost
    to how u are doing it. this is our program that we are using from
    our pc thru the serial cable. We need to get this going thru the
    serial cable now, and later on in the future we'll look at the
    wireless communication .
    Where do we go from here?
    '{$STAMP BS2}
    ' if you are not using a BS2 you will have to change
    ' the baud rate (which is 2400) values to work on the
    ' version of stamp that you have
    output 2 ' + side of buzzer connected
    to pin 2
    freqout 2, 1500, 4000 'tone for buzzer (check
    battery)
    low 12 'set pin 12 for output
    (servo 1)
    low 13 'set pin 13 for output
    (servo 2)
    pulse_count var word 'declare a variable
    control var byte ' (same)
    again:
    'serin 16,16780,[noparse][[/noparse]WAIT ("HELLO")]
    'serout 16,16780,[noparse][[/noparse]13,10,"GOODBYE",13,10]
    serin 16,16780,[noparse][[/noparse]control]
    if control = "L" then left
    if control = "R" then right
    if control = "F" then forward
    if control = "B" then backward
    if control = "U" then uturn
    goto again
    LEFT: 'quick left turn
    for pulse_count = 1 to 75
    pulsout 12, 500
    pulsout 13, 500
    pause 20
    next
    goto again
    RIGHT: 'quick right turn
    for pulse_count = 1 to 70
    pulsout 12, 1000
    pulsout 13, 1000
    pause 100
    next
    goto again
    FORWARD: 'do a step forward at max
    speed
    pulsout 12, 1000
    pulsout 13, 500
    pause 1
    next
    goto again
    BACKWARD: 'do a step backward at max
    speed
    pulsout 12, 500
    pulsout 13, 1000
    pause 1
    next
    goto again
    UTURN: 'do a complete U turn
    for pulse_count = 0 to 140
    pulsout 12, 1000
    pulsout 13, 1000
    pause 20
    next
    goto again
    the
    you
    from your
    > PC too.
    > Sort of like this:
    > pin3 right
    > pin4 left
    > pin5 stop
    > MainLoop:
    > Goto MainLoop
    > forward:
    > goto mainloop:
    > reverse:
    > goto mainloop
    > et cetera
    > hey,
    now,
    i
    the
    > please help...
    > It
    > and it
    > serial I/O
    > > Hi,
    to
    able
    press
    > there
    > > Dave
    > Subject and
    Subject and
    edited 2002-02-27 12:12
    Using the serial port for this will be a problem, because the program will
    stop
    until it receives a character byte from your PC.
    serin 16,16780,control
    So when the program encounters this line it will wait for a byte to come
    from your
    PC.
    Have you tried sending a command multiple times? like so
    FFFFFFFFFF robot goes forward
    then RRRRRRRRRRR unitl robot turns right
    then FFFFFFFFFF...until robot goes forward again.
    When the robot is down in your motor control routiones, it will ignore
    everything
    from the serial port.
    Another thing is unless you send the servo commands (the pulsout commands)
    about 20 times per second, the servos will stop.
    So you need a command like Forward within your loop
    again:
    serin 16,16780,[noparse][[/noparse]control] 'don't know about this, the program will stop
    ' and wait for a byte, you'll need to keep
    'typing a letter on the keyboard for this get
    'through the serial command
    'When the program is executing these IF statements it'll ignore the
    keyboard
    forward 'need this to keep the servos from stoping
    goto again
    From: ioa_windsor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4QUtGPlOopcnZx9-3BmLYmSMgWH_k0mz0wJU9_QWTsfdo_b9XC3cdL_YNSOjc_8bmS2UBjUPY4NaN2LjAs9v]ioa_windsor@y...[/url
    Sent: Tuesday, February 26, 2002 10:22 PM
    '{$STAMP BS2}
    to pin 2
    battery)
    (servo 1)
    (servo 2)
    again:
    goto again
    pulsout 12, 500
    pulsout 13, 500
    pause 20
    next
    goto again
    pulsout 12, 1000
    pulsout 13, 1000
    pause 100
    next
    goto again
    speed
    pulsout 12, 1000
    pulsout 13, 500
    pause 1
    next
    goto again
    speed
    pulsout 12, 500
    pulsout 13, 1000
    pause 1
    next
    goto again
    pulsout 12, 1000
    pulsout 13, 1000
    pause 20
    next
    goto again
    the
    you
    from your
    > PC too.
    > Sort of like this:
    > pin3 right
    > pin4 left
    > pin5 stop
    > MainLoop:
    > Goto MainLoop
    > forward:
    > goto mainloop:
    > reverse:
    > goto mainloop
    > et cetera
    > hey,
    now,
    i
    the
    > please help...
    > It
    > and it
    > serial I/O
    > > Hi,
    to
    able
    press
    > there
    > > Dave
    > Subject and
    Subject and
    edited 2002-02-28 09:45
    >stop
    >from your
    >PC.
    You can put an extra variable in that line to tell serin that if it doesn't
    receive anything within x time period, to go to another point in the
    program.
    Example:
    SERIN 16, 396, 200, Checkbuttons, [noparse][[/noparse]DatafromPC]
    The above command says:
    Receive serial data on port 16 at 2400 baud, 8, N, 1 (396).
    If no data after 200ms, then branch to the routine called "Checkbuttons".
    If data is received, put it in the variable "DatafromPC".
    http://www.lennard.net.nz/
    Ben Lennard, NCEE, Dip EE
    Web Hosting and Electronics R&D
    Club Coordinator, Victoria University of Wellington Hockey Club
    Hm: +64 4 972 7567
    Mb: +64 21 536 627
    87 Spencer Street
    Crofton Downs
    Wellington
    New Zealand
    "To the optimist, the glass is half full. To the pessimist, the glass is
    half empty. To the engineer, the glass is twice as big as it needs to be."
    No animals were harmed in the transmission of this email, although the
    Dog next door is living on borrowed time, let me tell you! Those of you
    with an overwhelming fear of the unknown will be gratified to learn that
    there is no hidden message revealed by reading this warning backwards.
    Subject: RE: [noparse][[/noparse]basicstamps] Re: Basic stamp 2
    Date: Thu, 28 Feb 2002 1:12 AM
    stop
    from your
    PC.
    everything
    again:
    keyboard
    goto again
    From: ioa_windsor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WiUfawhVB_aiDgCuCwKzjGYCGse8QQExTwtAw9mzK8k5QgHr4JnPOLHSl_Xu5SRRK5HzYq5d5f_S9A]ioa_windsor@y...[/url
    '{$STAMP BS2}
    to pin 2
    battery)
    (servo 1)
    (servo 2)
    again:
    goto again
    pulsout 12, 500
    pulsout 13, 500
    pause 20
    next
    goto again
    pulsout 12, 1000
    pulsout 13, 1000
    pause 100
    next
    goto again
    speed
    pulsout 12, 1000
    pulsout 13, 500
    pause 1
    next
    goto again
    speed
    pulsout 12, 500
    pulsout 13, 1000
    pause 1
    next
    goto again
    pulsout 12, 1000
    pulsout 13, 1000
    pause 20
    next
    goto again
    the
    you
    from your
    > PC too.
    > Sort of like this:
    > pin3 right
    > pin4 left
    > pin5 stop
    > MainLoop:
    > Goto MainLoop
    > forward:
    > goto mainloop:
    > reverse:
    > goto mainloop
    > et cetera
    > hey,
    now,
    i
    the
    > please help...
    > It
    > and it
    > serial I/O
    > > Hi,
    to
    able
    press
    > there
    > > Dave
    > Subject and
    Subject and
    edited 2002-03-02 00:47
    thnx for the tip, but i still need to improve the pogram a little
    bit.
    so far this is what my program looks like:
    its still pretty much doing the same thing. can you help with
    reprogramming it, so that we can interupt it while its performing
    one of the functions such as forward, to make it turn left or right.
    Please help, as we are getting close to the deadline..if certain
    hardware or software is needed etc.. thnx for your time
    '{$STAMP BS2}
    output 2
    output 3
    output 7
    output 1
    ' + side of buzzer connected to pin 2
    'freqout 2, 1500, 4000 'tone for buzzer (check
    battery)
    (servo 1)
    (servo 2)
    DatafromPC var byte
    parameter var byte ' (same)
    curvature var word ' (same)
    dist var byte 'DIRR
    sensors var nib
    dout con 5 'output to the DIRRS.
    din con 6 'input from the DIRRS.
    high dout 'raise output pin DIRR.
    input din 'set to in
    again:
    if control = "A" then alarm
    if control = "Y" then rampup 'accelerates from zero speed
    if control = "Z" then rampdown 'decelerates to zero speed
    if control = "X" then assignment 'this command gets a
    parameter
    if control = "C" then curveL
    if control = "E" then curveR
    if control = "D" then dirr
    if control = "H" then main
    goto again
    SERIN 16, 396, 1000, Checkbuttons, [noparse][[/noparse]DatafromPC]
    Checkbuttons:
    if DatafromPC = "L" then left
    if DatafromPC = "R" then right
    if DatafromPC = "F" then forward
    if DatafromPC = "B" then backward
    goto Checkbuttons
    'freqout 2, 2000, 3000
    'low 12
    'low 13
    main routine
    main:
    freqout 7, 1, 38500
    sensors.bit0 = in8
    freqout 1, 1, 38500
    sensors.bit1 = in0
    pause 40
    branch sensors, [noparse][[/noparse]backward1, right_turn,left_turn, forward1]
    forward1: pulsout 13,1000: pulsout 12, 500: goto main
    left_turn: pulsout 13,500: pulsout 12, 500: goto main
    right_turn: pulsout 13,1000: pulsout 12,1000: goto main
    backward1: pulsout 13,500: pulsout 12, 1000: goto main
    pulsout 12, 500
    pulsout 13, 500
    pause 20
    next
    goto again
    program will
    > >stop
    to come
    > >from your
    > >PC.
    it doesn't
    the
    > program.
    > Example:
    > Hm: +64 4 972 7567
    > Mb: +64 21 536 627
    > 87 Spencer Street
    > Crofton Downs
    > Wellington
    > New Zealand
    glass is
    needs to be."
    the
    of you
    learn that
    backwards.
    > From: "Earl Bollinger" <earlwbollinger@a...>
    > To: <basicstamps@y...>
    program will
    > stop
    to come
    > from your
    > PC.
    ignore
    > everything
    commands)
    > again:
    will stop
    the
    > keyboard
    > goto again
    > '{$STAMP BS2}
    > to pin 2
    > battery)
    > (servo 1)
    > (servo 2)
    > again:
    > goto again
    > pulsout 12, 500
    > pulsout 13, 500
    > pause 20
    > next
    > goto again
    > pulsout 12, 1000
    > pulsout 13, 1000
    > pause 100
    > next
    > goto again
    > speed
    > pulsout 12, 1000
    > pulsout 13, 500
    > pause 1
    > next
    > goto again
    > speed
    > pulsout 12, 500
    > pulsout 13, 1000
    > pause 1
    > next
    > goto again
    > pulsout 12, 1000
    > pulsout 13, 1000
    > pause 20
    > next
    > goto again
    > the
    > you
    well
    > from your
    > > PC too.
    > > Sort of like this:
    > > pin3 right
    > > pin4 left
    > > pin5 stop
    > > MainLoop:
    > > Goto MainLoop
    > > forward:
    > > goto mainloop:
    > > reverse:
    > > goto mainloop
    > > et cetera
    > > hey,
    > now,
    then
    > i
    > the
    to
    > > please help...
    receiver.
    > > It
    > > and it
    > > serial I/O
    > > > Hi,
    > to
    > able
    > press
    > > there
    > > > Dave
    > > Subject and
    > Subject and
    Subject and
    Subject and
    edited 2002-08-31 02:20
    i am wondering if there is a way of making the basic stamp 2 read
    frequeny as like a frequency counter. the counter only has to read
    upto 20 mhz.. i have the max7219 with 3 displays tied to it. i only
    need to have the display read 3 digits after the decmal point. i
    dont need any specail input circuit since it will be reading a 5
    volt square way.
    thank you neil
    edited 2002-08-31 14:50
    Sure is:
    COUNT pin,period,variable
    Count is an instruction which counds the pulses per time period on a
    given pin and stores it into the the variable.
    Easy, huh?
    -Martin Hebel
    only
    > volt square way.
    > thank you neil
    edited 2002-09-01 00:26
    The Stamp BS2 maximum frequency input for COUNT is 120khz (a little
    higher for the 'sx and 'p). In order to get up to 20mhz, you will
    need a divider circuit, something like a /200 or /256. That could be
    something like a 74HC4060.
    -- Tracy
    >Sure is:
    >Easy, huh?
    >-Martin Hebel
    >only
    >> volt square way.
    > > thank you neil
    edited 2004-01-08 18:19
    Hello ,
    Is et posible to fix 2 bs2 together , and how you program the I/O ,
    I need 20 I/O for mine project and I will to dit with 2 basic stamps
    2 , and than I have more memory also , I hoop
    Kind regards
    Erwin
    edited 2004-01-08 19:48
    dont know what your application is. would be easier to use BS2p40. i have
    used dual BS2's in many applications. like i said it all depends on the
    app. best regards
    -Garyd
    Kyocera-Wireless
    At 06:19 PM 1/8/2004 +0000, you wrote:
    >Hello ,
    >Kind regards
    >Erwin
    >Yahoo! Groups Links
    >To visit your group on the web, go to:
    > http://groups.yahoo.com/group/basicstamps/
    >To unsubscribe from this group, send an email to:
    >Your use of Yahoo! Groups is subject to:
    You can use one Stamp to be a slave IO processor for the second. This
    article may help:
    http://www.parallax.com/dl/docs/cols/nv/vol3/col/81.pdf
    -- Jon Williams
    -- Dallas Office
    From: on4aij [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ymYXQwuhosGPrYAM98wZasH08fROXPXoHI20vp2mRNm_iwxBkgcEbWUPziWWpq5svBuPZhGc-zXQ]on4aij@y...[/url
    Sent: Thursday, January 08, 2004 12:20 PM
    Hello ,
    Kind regards
    Erwin
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
