(OT) Maths Question
Sorry about bothering every one with this but it's Late (Here) and I need to
work it out
I'm just wondering if any one could help me with a formula to do the
following :
I have 6 Bits of info that I have assigned 6 numbers eg 1,2,4,8,16,32,
I want to be able to have any combination of the Bits and then pass the
single number to a program
and work out via a formula what the original combination of Bits was.
Is there an easy way of working this one out ?
Any assistance would be greatly appreciated
Dean Stevenson
Email dean@i...
work it out
following :
Dean Stevenson
Email dean@i...
I don't understand your problem description.
Ray McArthur
To: <basicstamps@egroups.com>
Sent: Tuesday, August 15, 2000 8:45 AM
Subject: [noparse][[/noparse]basicstamps] (OT) Maths Question
to
> work it out
> following :
could use the difference between the numbers to determine the initial bit
pattern?
From: rjmca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=H3LxBgAHN8_E-vplj2-mv3gtX2GLc2XnFO-9UdhajsJpntSetYSG0NWx0r7xRuIFk1FPEeiPseaCgQ]rjmca@w...[/url
Sent: Tuesday, August 15, 2000 1:46 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] (OT) Maths Question
Dean:
Ray McArthur
to
> work it out
> following :
He wants to have 8 bits 1,2,4,8,16,32,64,128 and combine them into a single
number to send (such as 43). On the other end he wants to receive the 43
and have a function tell him that it was the bits of 32, 8, 2, and 1. I
know a very "dirty" way to do this in Visual Basic, but I'm sure there is a
better Stamp solution. I'm looking forward to seeing the answer as well.
Shawn
From: rjmca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0nKY_1Zu9Dn_m278Hyhe1wu-B3Y4JfX1nUmTCz4j5k-ALcxZm8yc1vErRRb9YO_-vZ8OJcGT6u08TmJ2-A]rjmca@w...[/url
Sent: Tuesday, August 15, 2000 11:46 AM
Dean:
Ray McArthur
to
> work it out
> following :
> >From what I understand:
It's all represented that way internally. If you want to look at
individual bits, you'd use a bit and function
bytevalue&1 (will be 0 or 1)
bytevalue&2 (will be 0 or 2)
bytevalue&4 (will be 0 or 4)
a cheap way to do this would be something like
loop:
if (bytevalue & (1 << i)) = 0 then bitnotset
' at this point the ith bit in bytevalue is high,
' so do soemthing with it.
bitnotset:
i = (i+1)//8
goto loop:
Combining multiple 'bit' variables into a byte / word for transmission
isn't particularly useful - it's already represented that way internally.
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
have a bit sequence of 001010 = 2 + 8 = 10). At the other end you use
the AND command with 1,2,4,8,16,32 to see if the bit is high or low.
Grant McPherson
www.ozsonic.com
--- In basicstamps@egroups.com, "Production Technology, Inc."
<FIXEMERD@N...> wrote:
> not exactly sure about the problem, however, it would seem to me
that you
initial bit
> pattern?
> From: rjmca [noparse][[/noparse]mailto:rjmca@w...]
> Dean:
> Ray McArthur
> From: Dean Stevenson <dean@i...>
and I need
> to
> > work it out
the
> > following :
1,2,4,8,16,32,
pass the
was.
encoding algorithem*, and we did not understand his question?!?\
-Edward Kindler
Rather than taking up a lot of space having to do branching IF statements
with every possible
combination,
I think that I have worked out a way to reduce the number of IF THEN
statements,
I will post the code when I get it debugged
Many thanks for the help
Dean Stevenson
Sent: Wednesday, August 16, 2000 1:19 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: (OT) Maths Question
> So was his question just about binary math??? or was he looking for an
> -Edward Kindler
