Temperature sensor
Hi everybody,
I'm working on a central heating control project. I have to get the
temperature from different places, which are far from the control unit.
I'd like to use PT100 sensors, because they're very reliable and linear.
Does somebody know if there is a chip which converts the PT100 resistance
into a CURRENT value ? I'd like to get a current value to avoid voltage drop
on the line.
There is maybe another solution, like integrated temperature sensors. Any
idea is welcome !
Thanks in advance for your help !
Philippe Derenne
on the line.
idea is welcome !
Philippe Derenne
twisted pair circuit for the LM35.
To: <basicstamps@egroups.com>
Sent: Thursday, August 10, 2000 3:15 PM
Subject: [noparse][[/noparse]basicstamps] Temperature sensor
> Hi everybody,
drop
> on the line.
> idea is welcome !
> Philippe Derenne
Thanks for your fast answer ! I got the information from this site, it looks
like that's what I'm looking for !
Best regards,
Philippe Derenne
Sent: Friday, August 11, 2000 12:39 AM
Subject: Re: [noparse][[/noparse]basicstamps] Temperature sensor
> Check out National Semiconductors website for the LM35. They have a good
> > Hi everybody,
resistance
> drop
> > on the line.
Any
> > idea is welcome !
> > Philippe Derenne
You might also look into the AD590 or AD592, which are a linear current
output temperature sensors meant for use on long cables.
http://www.emesystems.com/OWL2face.htm#AD590
http://www.stampsinclass.com/downloads/em3.pdf
--Tracy
Thanks for those very usefull informations !
Philippe Derenne
Sent: Friday, August 11, 2000 1:17 AM
> Hi Phillipe,
> --Tracy
Your welcome, make sure to use the right case style for your app. The
LM35DZ is the most general and it has a plastic package. The most usefull
is the T-220 syle.
I have used the twisted pair circuit before and it works well. Using an
op-amp will help with the noise too.
Matthew
Sent: Thursday, August 10, 2000 3:48 PM
> Hi Matthew,
looks
> Best regards,
> Philippe Derenne
> From: Matthew Lewis <aiden.bell@h...>
good
> > > Hi everybody,
unit.
linear.
> resistance
voltage
> > drop
> > > on the line.
> Any
> > > idea is welcome !
> > > Philippe Derenne
>Hi everybody,
>on the line.
>idea is welcome !
>Philippe Derenne
Hi Philippe -
The easiest, quickest, and most efficient solution is probably to use one
of the various Honeywell (or others) Integrated HVAC Controller systems,
and modify the control of that, if necessay, with a microcontroller.
Otherwise, you have a rather ambitious project ahead of you which may tax
both your time and your patience. Of course, packaged systems aren't much
fun :-)
That aside, Dallas Semiconductors [noparse][[/noparse]www.dalsemi.com ] has a thermostat on a
chip (see below), as well as various temperature sensor chips and other
allied components. They offer a complete line of time/date, and
environmental condition oriented chips. Their thermal management offerings
include 3-wire, 2-wire, and 1-wire types. Steer clear of the Dallas 1-wire
units, since there are timing considerations which are difficult (if not
impossible) to overcome with the Stamp (alone). If the 1-wire systems
appeal to you, I would personally opt for a MicroChip PIC and use either
C++ or PBasic Pro from Micro Engineering Labs [noparse][[/noparse] www.melabs,com ]. I
purchased mine from Chuck at ElProducts
[noparse][[/noparse] www.elproducts.com ], and am quite pleased with it. It offers the ability
to code in assembler (as many C compilers do) for routines where the Basic
language is inadequte for the task, or too slow. The system follows that of
the Parallax PBASIC Stamps, and accepts most of it without much change.
Thermostat-On-A-Chip
There are various offerings in DS-162x series, and with various features.
The DS-1624 (a 2-wire unit) has 256 bytes of EEPROM for saving data
(reducing the on Stamp data storage requirements), is multi-drop (up to 8
units per bus), and can be controlled and addressed via the PABSIC
operators Shiftin/Shiftout (I believe). This is a high-precision,
"direct-to-digital" [noparse][[/noparse]tm] unit.
Please remember there is a 2-byte (13 bit) data transfer, due to the
greater accuracy of this device over other 8-bit units. This will
necessitate allocation of WORD length variables on the Stamp/PIC.The
DS-1629 also includes an RTC is you find that is a requirement for your design.
The FTP site [noparse][[/noparse] ftp://ftp.dalsemi.com/pub/ ] has zipped packages of chip
data and applications information, or the inline HTTP links can be used as
well. A less integrated and less accurate non-networked solution (4-20 mA
examples are often given, however, with external components) can be
obtained by use of the LM-35 style chips by National [noparse][[/noparse] www.natsemi.com ]
and others. Parallax [noparse][[/noparse]www.parallaxinc.com ] offers APPMods for these
products. From my point of view, these LM-35 (type) chips generally fall
short in two areas:
1) they are not directly addressable, and
2) the output is analog, as opposed to digital
Neither shortfall prevents thier use, but the Dallas parts include all that
PLUS the EEPROM and thermostat function - all on one chip. Additionally,
the Dallas chips have an applications note for an evaluation board (DS-1702-K,
[noparse][[/noparse] http://www.dalsemi.com/news/resource/rsc9_1702k.html ], which is actually
a temperature controller (such as you may be presently considering), to
ease re-inventing the wheel, or just to evaluate present (and future) free
samples, as they become available.
Hope that helps.
Bruce Bates
Hi everybody,
- on2bbp@pi.be
Joost Luyten
Werftsesteenweg 44
2220 Heist op den Berg
Belgium
Thanks for this advice. It looks like those Dallas ICs are closer to the
Stamp than analog sensors...
I went to your site, your LawnMover is very interesting ! I've read
somewhere that you're about to translate those pages to english... this
would be nice !
Best regards,
Philippe Derenne
Sent: Friday, August 11, 2000 8:06 AM
Subject: SV: [noparse][[/noparse]basicstamps] Temperature sensor
Hi Philippe!
Well, i have already read several great ansvers to your query e.g. th
excellent LM 35.
However, just to make sure you are aware of the great temp-sensors from
"dallas semiconductors"
Theese smart chips measures the temp an sends out the temp as serial code,
that can be directly connected to
the STAMP, no extras needed. AND, one type of "dallas sensor" has individual
adresses, so you can hook as many as you want on a long serial cable and
from your STAMP "ask" for each temperature...
The rechnique is described in several of the PDF-documents regarding "Stamp
in class" at parallax...try the "earth and measure" work book.
I think that therar are more "serial-sensors" from dallas, like an small
sensor, with "individual adress", that detects an digital input, so you
could monitor both temperatures and "status" of various stuff like motors,
pumps alarms etc...all on the same wire!
Greetings
Hans Forsberg
http://www.robotshop.nu
Build your own STAMP powered LawnMover...
Ursprungligt meddelande
Fr
Congratulations, your answer is the more complete I received !
Many thanks for your advice, and for those interesting web addresses. I'll
have a look there.
Best regards,
Philippe Derenne
Sent: Friday, August 11, 2000 9:17 AM
> At 12:15 AM 8/11/00, you wrote:
> >Hi everybody,
drop
> >on the line.
> >idea is welcome !
> >Philippe Derenne
> Hi Philippe -
one
> fun :-)
1-wire
ability
of
design.
as
> short in two areas:
that
(DS-1702-K,
actually
> Hope that helps.
> Regards,
> Bruce Bates
It's funny to have a conversation with another Belgian thru a server in USA !
Thanks for your idea. I think the most difficult part of my job will be choosing between all answers I got...
Best regards,
Philippe Derenne
Computer Solutions
Goz
Try looking at our temperature and humidity sensor product the RHT7 at
www.technologykit.com
It will transmit the temperatures and humidity over long distances, and
directly interface with a stamp or microprocessor without the need for
external circuitry. Another "plus" of our unit is the onboard calibration
system.
Sincerely,
Charles Page, President, Technology Electronics, Ltd.
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Thursday, August 10, 2000 6:18 PM
>Hi everybody,
drop
>on the line.
>idea is welcome !
>Philippe Derenne
Thanks for this information, I'll have a look on your site.
Best regards,
Philippe Derenne
Sent: Sunday, August 13, 2000 2:40 AM
> Hello Philippe,
> system.
> Sincerely,
> From: Philippe Derenne <derennep@s...>
> >Hi everybody,
> drop
> >on the line.
> >idea is welcome !
> >Philippe Derenne
How can i convert the 8bit output from the ADC0804 to a two digit
display?
Best regards,
Kalun mailto:klnlau@v...
value of 23 and you want to display this as two characters '2' '3', or ascii
3233 ?
copy the 1 byte value to a new variable (x)
shift x right 4 bits (integer divide by 16 if shifting isn't available)
lookup x,'0123456789ABCDEF', x
'x is now the first digit
mask the upper 4 bits off the original value using logical and x'0f'
then use the same lookup command as above and then you have the second digit
too
Don Russell
Position? Let's see.. .I'm at the corner of "Walk" and "Don't Walk"
Sent: Friday, February 02, 2001 8:17 PM
Subject: [noparse][[/noparse]basicstamps] temperature sensor
> Hello
> display?
> Best regards,
assumed you wanted to display the 8 bit value in HEX. If you wanted to
display the 8bit value in decimal, you may need up to three digits (0-255).
If you want the 8bit value displayed as a decimal number in the range 0-255
you can use the DEC modifier on the SEROUT command and the Stamp will do the
necessary conversion auto-magically. :-)
Don Russell
> Hello
> display?
> Best regards,
sensor output is lowest the op amp output is 4ma and when the sensor is
highest you get 20 ma output. Not a big task, but would take a little
bit of linear design calculations. An instrumentation style op Amp
might be required for high accuracy. You would need to digitize the
signal to get it reliably back to the stamp. Maxium make some nice
cheap A/D converters.
Leroy
* Leroy Hall *
* 317 Cherokee Drive *
* Loveland, Ohio - USA 45140-2404 *
* Phone: (513) 697-7539 *
* Cell : (513) 300-8632 *
* Email: leroy@f... *
* Home page URL: http://home.fuse.net/leroy/ *
* Resume URL: http://home.fuse.net/leroy/resume.htm *
* Leroy Hall *
I am making a testpannel for my students. In it I incorporate a
temperature sensor and a basic stamp 2.
I need the value of the capacitor to use or how to calculate it. The
sensor is a NTC (20Kohm At 0°C) I will be using the RCTIME command
in the program and the schematic of the "What's a microcontroller?
page 201.
The BS2 will switch an outpin high when a student tuches te
temperature sensor.
Thank you,
>page 201.
>temperature sensor.
>Thank you,
Choose the capacitor so that the time constant will be about 1 or 2
milliseconds. (BS2 a count of 500 or 1000)
If the circuit is set up so that the capacitor voltage approaches the
~1.3 volt Stamp threshold from above the formula is:
RCtime 0,1,x
tm = 2*x ' tm= 1.35 * R * C
So for a 2 millisecond time constant with R=20kohms,
C = 2000 microseconds / (1.35 * 20000 ohms) = 0.074 microfarad.
for convenience, you might use a 0.1 microfarad capacitor, and the
time at 0 degrees would be approximately
tm = 1.35 * 0.1 microfarad * 20000 ohms = 2700 microseconds
or a count of x=about 1350 on a BS2. You students are going to have
to calibrate it in any case. See what count they get before and
after touching it, and then make their output pin logic split the
difference.
The formula is different if the capacitor voltage approaches the
threshold from below:
RCtime 0,0,x
tm 2*x ' tm = 0.3 * R * C
more reference
http://www.emesystems.com/BS2rct.htm#RCtime
-- Tracy
This is what I needed.
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0eYaa-AKESSTJ2dcmjm0cMBa31pNwKnEsDJ-VUpgSifIT7uvjUCUwUJwGEkRBfheBdtiB9gEt74QSlgpSQ]tracy@e...[/url
Sent: maandag 1 maart 2004 19:57
>Dear all,
>temperature sensor and a basic stamp 2. I need the value of the
>capacitor to use or how to calculate it. The sensor is a NTC (20Kohm At
>0°C) I will be using the RCTIME command in the program and the
>schematic of the "What's a microcontroller? page 201.
>temperature sensor.
>Thank you,
RCtime 0,1,x
C = 2000 microseconds / (1.35 * 20000 ohms) = 0.074 microfarad. for
tm = 1.35 * 0.1 microfarad * 20000 ohms = 2700 microseconds or a count
difference.
RCtime 0,0,x
more reference
-- Tracy
Yahoo! Groups Links
