BS1 Instruction Times
Here's a list of BS1 instruction execution times. In each case the
indicated times reflect the total time, in microseconds, spent in
the instruction(s).
If a specific BS1 instruction sequence timing is desired, better ask
quick before I tear down this setup.
This info is fair game for inclusion in any other collection of
Stamp info as desired.
Steve
HIGH 3
250 usec
INPUT 3
246 usec
TOGGLE 3
248 usec
REVERSE 3
246 usec
PAUSE 1
1221 usec
PAUSE 2
2228 usec
SLEEP 1
2,550,645 usec
PULSOUT 3,1
343 usec
PULSOUT 3,2
374 usec
PULSOUT 3,3
384 usec
PULSOUT 3,10
454 usec
GOTO b
b:
419 usec
GOSUB b
1338 usec
b:
RETURN
FOR i = 1 TO 1
NEXT
988 usec
FOR i = 1 TO 2
NEXT
1903
FOR i = 1 TO 10
NEXT
9066
LET i = 1
427
LET i = x
456 usec
IF x = y THEN b (when x != y)
509
IF x = y THEN b (when x = b)
b:
660 usec
READ 0,i
853 usec
WRITE 0,i
4731 usec
NAP 0
39,566 usec
NAP 1
59,025 usec
NAP 7
2,510,551 usec
BRANCH x,(b,c,d)
[noparse][[/noparse]***]
for x = 3 (x out of range), 631 usec
b:
for x = 0, 552 usec
c:
for x = 1, 687 usec
d:
for x = 2, 789 usec
LOOKUP x,(0,1,2),y
for x = 0, 659 usec
for x = 1, 659 usec
for x = 2, 659 usec
for x = 3 (x out of range), 633 usec
LOOKDOWN x,(0,1,2),y
for x = 0, 703 usec
for x = 1, 703 usec
for x = 2, 703 usec
for x = 3 (x out of range), 663 usec
(end of list)
the instruction(s).
Steve
HIGH 3
250 usec
INPUT 3
246 usec
TOGGLE 3
248 usec
REVERSE 3
246 usec
PAUSE 1
1221 usec
PAUSE 2
2228 usec
SLEEP 1
2,550,645 usec
PULSOUT 3,1
343 usec
PULSOUT 3,2
374 usec
PULSOUT 3,3
384 usec
PULSOUT 3,10
454 usec
GOTO b
b:
419 usec
GOSUB b
1338 usec
b:
RETURN
FOR i = 1 TO 1
NEXT
988 usec
FOR i = 1 TO 2
NEXT
1903
FOR i = 1 TO 10
NEXT
9066
LET i = 1
427
LET i = x
456 usec
509
b:
660 usec
READ 0,i
853 usec
WRITE 0,i
4731 usec
NAP 0
39,566 usec
NAP 1
59,025 usec
NAP 7
2,510,551 usec
BRANCH x,(b,c,d)
b:
for x = 0, 552 usec
c:
for x = 1, 687 usec
d:
for x = 2, 789 usec
LOOKUP x,(0,1,2),y
for x = 0, 659 usec
for x = 1, 659 usec
for x = 2, 659 usec
for x = 0, 703 usec
for x = 1, 703 usec
for x = 2, 703 usec
(end of list)
If you are going to put this on your site, I'll link to it from the FAQ.
Otherwise, I'll post in there if you would like.
Al Williams
AWC
*Basic Stamp FAQ: http://www.al-williams.com/wd5gnr/stampfaq.htm
> From: S Parkis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1AvFhuL5RIunx38czThuq7iXy1UGuyUcJqDV-uHlsDaRqrPcRc8uO2BND2KJCVpySwm28JkhUOs8B1ZJqyng2Q]parkiss@e...[/url
> Sent: Thursday, August 10, 2000 6:43 AM
> To: basicstamps@egroups.com; whawaii@m...
> Subject: [noparse][[/noparse]basicstamps] BS1 Instruction Times
> the instruction(s).
> Steve
> HIGH 3
> 250 usec
> INPUT 3
> 246 usec
> TOGGLE 3
> 248 usec
> REVERSE 3
> 246 usec
> PAUSE 1
> 1221 usec
> PAUSE 2
> 2228 usec
> SLEEP 1
> 2,550,645 usec
> PULSOUT 3,1
> 343 usec
> PULSOUT 3,2
> 374 usec
> PULSOUT 3,3
> 384 usec
> PULSOUT 3,10
> 454 usec
> GOTO b
> b:
> 419 usec
> GOSUB b
> 1338 usec
> b:
> RETURN
> FOR i = 1 TO 1
> NEXT
> 988 usec
> FOR i = 1 TO 2
> NEXT
> 1903
> FOR i = 1 TO 10
> NEXT
> 9066
> LET i = 1
> 427
> LET i = x
> 456 usec
> 509
> b:
> 660 usec
> READ 0,i
> 853 usec
> WRITE 0,i
> 4731 usec
> NAP 0
> 39,566 usec
> NAP 1
> 59,025 usec
> NAP 7
> 2,510,551 usec
> BRANCH x,(b,c,d)
> b:
> for x = 0, 552 usec
> c:
> for x = 1, 687 usec
> d:
> for x = 2, 789 usec
> LOOKUP x,(0,1,2),y
> for x = 0, 659 usec
> for x = 1, 659 usec
> for x = 2, 659 usec
> for x = 0, 703 usec
> for x = 1, 703 usec
> for x = 2, 703 usec
> (end of list)
