Decoding 2 bit to 4
Does anyone know of an IC that EXACTLY matches this truth table:
IN OUT
| a b | 1 2 3 4 |
| 0 0 | 1 0 0 0 |
| 0 1 | 0 1 0 0 |
| 1 0 | 0 0 1 0 |
| 1 1 | 0 0 0 1 |
The 74x195 & 74x155 have the outputs reversed from this, and I would have to
use a set of inverters, and i REALLY needed to keep the # of devices to a
minimum. So, if anyone knows of a device...
Thanks in advance,
Edward Kindler
IN OUT
| a b | 1 2 3 4 |
| 0 0 | 1 0 0 0 |
| 0 1 | 0 1 0 0 |
| 1 0 | 0 0 1 0 |
| 1 1 | 0 0 0 1 |
Thanks in advance,
Edward Kindler
CD4028 is straightforward.
CD4514 can do this using q8 q9 q10 q11 as outputs and setting A3 High.
The CD4051 8ch analog multiplex is OK (must use pull up /or down
resistors ? ).
ACJacques
> IN OUT
> | a b | 1 2 3 4 |
> | 0 0 | 1 0 0 0 |
> | 0 1 | 0 1 0 0 |
> | 1 0 | 0 0 1 0 |
> | 1 1 | 0 0 0 1 |
> Thanks in advance,
> Edward Kindler
the rest of your circuit). If you can't find one, try a 74X238 and ground
the extra input (and ignore the extra outputs).
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller at
http://www.al-williams.com/awce/pak1.htm
> From: RiffRaff82@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jvWyjfxKGI1Pq3_J7utIE8kGdEQeGu9C2CL8JHa1YFV9D9ujp2QGUtJryOytUZJlUxFz1LiGirw]RiffRaff82@a...[/url
> Sent: Sunday, August 06, 2000 6:51 PM
> To: SeattleRobotics@egroups.com; basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Decoding 2 bit to 4
> IN OUT
> | a b | 1 2 3 4 |
> | 0 0 | 1 0 0 0 |
> | 0 1 | 0 1 0 0 |
> | 1 0 | 0 0 1 0 |
> | 1 1 | 0 0 0 1 |
> would have to
> Thanks in advance,
> Edward Kindler
> IN OUT
>| a b | 1 2 3 4 |
>| 0 0 | 1 0 0 0 |
>| 0 1 | 0 1 0 0 |
>| 1 0 | 0 0 1 0 |
>| 1 1 | 0 0 0 1 |
Either of the following decoders will ehibit the outputs you desire:
CD4028 National HEF4028 Philips
Both are BCD to Decimal, or Binary to Octal - Decoders. Both are a bit of
overkill, as they are wider than necessary, but so it is with 4-bit
requirements.
The National part has 4 input buffers and 10 output buffers (2/4, 3/8,
4/10). Not sure about the Philips unit.
>Thanks in advance,
>Edward Kindler
Surely
Bruce Bates
>What you want is a 74X239 (where X is HC, L, F, whatever you need to match
Just for the record, the CD74xx238 is available from TI, and the 239 is
obso and only available from Rochester.
Bruce Bates
>Regards,
>Al Williams
>AWC
> > From: RiffRaff82@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yrizUp65W6MeiQaxXi36OeyxpR8sfzpmi9IVgYhyPn6EvuPzcNo2fPDftzV88IVaEtwgnnV6vGt5aFhdJw]RiffRaff82@a...[/url
> > IN OUT
> > | a b | 1 2 3 4 |
> > | 0 0 | 1 0 0 0 |
> > | 0 1 | 0 1 0 0 |
> > | 1 0 | 0 0 1 0 |
> > | 1 1 | 0 0 0 1 |
> > would have to
> > Thanks in advance,
> > Edward Kindler
Norm & Monda
Cozy MK IV #202
Ford V-6 Powered
To: <basicstamps@egroups.com>
Sent: Monday, August 07, 2000 1:06 AM
Subject: Re: [noparse][[/noparse]basicstamps] Decoding 2 bit to 4
> > IN OUT
> >| a b | 1 2 3 4 |
> >| 0 0 | 1 0 0 0 |
> >| 0 1 | 0 1 0 0 |
> >| 1 0 | 0 0 1 0 |
> >| 1 1 | 0 0 0 1 |
to
> requirements.
> >Thanks in advance,
> >Edward Kindler
> Surely
> Regards,
> Bruce Bates
> 74138 or equiv, decodes 3 bits, tie 1 bit off (low)
> Norm & Monda
74138 outputs are INVERTED of required.
ACJacques
> > > IN OUT
> > >| a b | 1 2 3 4 |
> > >| 0 0 | 1 0 0 0 |
> > >| 0 1 | 0 1 0 0 |
> > >| 1 0 | 0 0 1 0 |
> > >| 1 1 | 0 0 0 1 |
> to
Norm & Monda
Cozy MK IV #202
Ford V-6 Powered
Sent: Monday, August 07, 2000 8:15 AM
> > Norm & Monda
> ACJacques
> > > > IN OUT
> > > >| a b | 1 2 3 4 |
> > > >| 0 0 | 1 0 0 0 |
> > > >| 0 1 | 0 1 0 0 |
> > > >| 1 0 | 0 0 1 0 |
> > > >| 1 1 | 0 0 0 1 |
have
> > to
to a
