stampplot pro from selmaware
Hi:
Can anyone help me with stamp plot pro. I need to graph the output of
my A/D converter for a 12 or 24 hour period before save to file which
will come later. I'm trying to get familiar with the program but
after several small strokes I'm having some difficulty but am gettin
better all the time. I can program a little. Any help out there?
Thankyou
Jim
Thankyou
Jim
The simpliest way would be to set the plot up for 24 hours (Using
Config-->Axis change to hours and 24).
It depends what you want to save, if you want to save as a plot the
entire time, try not to take samples too frequently, keep it under
10,000 data points at least. (this would be one reading every 5
seconds for a single value to be 'debugged' from the Stamp-- 10,000
samples will require registered versions)
Set up logging so the plot saves at max time, and or stop at max
time. I think that's about it....
-Martin Hebel
SelmaWare Solutions
http://www.selmaware.com/s-plot --Graphical data acquisition and
control.
--- In basicstamps@egroups.com, "James Hardy" <jahardy33@h...> wrote:
> Hi:
of
which
gettin
> Thankyou
> Jim
I am using Hyper Terminal to capture to a txt file and then I open it with
Quattro Pro (Excel). Then I can use the math functions and graphing
functions to display the data visually. I can also bring the data into
MathCad and Maple V.
Matthew
To: <basicstamps@egroups.com>
Sent: Saturday, August 05, 2000 9:54 AM
Subject: [noparse][[/noparse]basicstamps] stampplot pro from selmaware
> Hi:
> Thankyou
> Jim
