Voltage Input
I have a remote control board that outputs a 9 volt digital circuit. The
question is how can I connect this to a stamp input? My understanding is
that the max on a stamp input is 5 volts.
Thank you
Tim
Thank you
Tim
Yes, the input to the Stamp is TTL, 5 volt max.
Use a voltage divider, like this:
10k 10k
9 volt signal
Stamp Stamp's
Pin Ground
By using a pair of 10k resistors, you will be dividing the 9volt signal
in half. So the Stamp will see 4.5 volts. 4.5 volts will be a TTL logic
'high' or '1'. Anything below ~1.4 volts will register as a logic low.
--- Jay
| Jay Nugent jjn@n... |____|
| Nugent Telecommunications www.nuge.com |
| Web-Pegasus www.webpegasus.com |
| (734)971-1076 (734)971-4529 /Fax |
| ISP & Modem Performance Monitoring Svcs. |
| Discount Reseller of 123.Net ISP Services|
| Internet Consulting / Linux SysAdmin |
| Web Hosting / DNS Hosting / Shell Accts. |
| Embedded Controllers / Engr. & Design |
\_________________________________________\__/
6:00am up 85 days, 12:00, 4 users, load average: 0.09, 0.02, 0.01
When I have a simular problem I use a 3 term. regular.
like a LM7805 or simular. Current should not be a problem
so you wont have to use a heat sink. Check it though to make sure.
Hope thjis helps. ______
IN GND. OUT
Frank
To: <basicstamps@egroups.com>
Sent: Friday, August 04, 2000 3:42 AM
Subject: [noparse][[/noparse]basicstamps] Voltage Input
> Thank you
> Tim
