BOE bot I/O pins and current
Hi guys,
I recently got a boe bot, and now that I've zipped right through the
experiments, I've got lots of ideas to try out. First question: I've heard
that if there's too much current draw/sink/something like that, the I/O
pins (and therefore the stamp) can be damaged. Is this true? If so, how do
you prevent this?
Second question: What is current sink and draw? I'm confused. :-)
Lastly: I know that servos such as the ones in the boe bot are designed to
run off of 4-6 volts (at least that's what my r/c airplanes battery packs
feed them.) Is if OK to run them off the 9 volts that come from the VIN or
should I hook it up to the VDD (regulated to 5 volts) on the boe? The
reason I ask is because on the boe you have a choice between connecting a 9
volt battery or 4 AA cells, and I've got a lot of 9 volt batterys and very
few AAs.
Thanks for putting up with my newbie questions!
Mike Ball, AKA Flaming Headphones
you prevent this?
few AAs.
the bs2 I/O pins can 20mA and sink 25mA each. You will have to use NPN
transistor switching if you require the use of a lot of output pins. Use
the Vdd to source your servo(s) but you may want to make sure that your amp
draw is in the exceptable range for the output of the Voltage Regulator that
you are using.
From: Flaming Headphones [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iCQoxDDyYbPQ3HE4v8_-ypWKn37voR02z4FXcLyGZ6K-WcTNck1_K7GrrtVofoeZNJKZAlLTEb531MmMN96_qRg]headphones99@i...[/url
Sent: Thursday, August 03, 2000 8:58 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] BOE bot I/O pins and current
Hi guys,
you prevent this?
few AAs.
limited in the amout of current it can supply to an external circet or how
much current it can source. also a device is limited in the amount of
current it can pull out of a circet or how much it can sink . when a stamp
is providing a positve voltage to some external componits the current flow
is a source flow. and conversly when some external componits are providing
voltage to the stamp io pins the stamp is sinking the current.
i have not tried to run servos higher than 6 volts some options are:
1. find the specs from a hobby store/ servo packaging/ off the web
2. try and find out if it burns up (destructive testing)
the higher the voltage that you run the servo at the more torque the servo
will output so a third option if the servos won't react well to the 9vdc is
to add a small 6vdc or what ever power supply being fed from the 9vdc
lw
Hi guys,
you prevent this?
few AAs.
Lincoln J. Worsham
liworsha@g...
Neuro Engineering Laboratory
NASA Ames Research Center MS 269-1
Moffett Field CA 94035-1000
Phone 650-604-0461
Fax 650-604-3594
http://www.arc.nasa.gov/computing.html
although they work well at 6 volts (and you get a bit more power than at
4.8V). Can you just step the 9V down to six with a 6 volt regulator (7806)?
Hope this helps, Duncan
