Wattmeter - article Nuts & Volts Ref?
>> Date: Sun, 30 Jul 2000 16:45:20 -0400
nuts and volts august 99
BUILD A DIGITAL WATT AND WATT-HOUR METER - Dan Harrison
There is a Nuts & Volts Archive on the Web.
Where is this archive? - I couldn't find it at the nuts & volts
site - only an offer to sell back issues and some program files.
Thanks... premena
________________________________________________________________
YOU'RE PAYING TOO MUCH FOR THE INTERNET!
Juno now offers FREE Internet Access!
Try it today - there's no risk! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
Thanks... premena
I passed on that reference from Larry Gaminde...did not go there. I just
searched Nuts & Volts site and found some back issue references, but could
not find Aug 99. Maybe Larry or someone else knows how to get there.
Ray McArthur
To: <basicstamps@egroups.com>
Sent: Tuesday, August 01, 2000 5:25 PM
Subject: [noparse][[/noparse]basicstamps] RE: Wattmeter - article Nuts & Volts Ref?
> Thanks... premena
It looks like a in depth article they are using a mc68hc705p6
microcontroller and it says that they needed the on chip timer running
at 10khz for watt hour accumulation. they used an optoisolator for the
input using a shunt across two inputs If your going to do it then get
the back issue it may answer all of your questions, If you need more
info get me offline
larry
> From: "rjmca" <rjmca@w...>
> Thanks... premena
http://www.edtn.com/embapps/emba027.htm
--Craig
From: LarryGaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ia9jpIb8D2Ewi78M8R6BhTGTV1DMug5_rU1POAGZFKKTvrhnF9crjhBAdHhykKzRIESUmn_Hz8GIV6sr114]lgaminde@t...[/url
Sent: Tuesday, August 01, 2000 9:12 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] RE: Wattmeter - article Nuts & Volts Ref?
I think you will have to get the back issue.
info get me offline
larry
> Thanks... premena
