New to Robotics
I 'd like to build a mobile robot using the BS2 with a motor mind B
connected to a 6v motor (from a little tykes ride on ). For steering I
was thinking of using a servo motor.
My question ,can the motor mind B be used without the TACH ?
Could someone steer me in the right direction? Maybe a stepper motor for
the steering,
the steering,
> connected to a 6v motor (from a little tykes ride on ). For steering I was
> thinking of using a servo motor. My question ,can the motor mind B be used
> without the TACH ? Could someone steer me in the right direction? Maybe a
> stepper motor for the steering,
I'm not familiar with the motor you're referring to, but I highly doubt
that the Motor Mind can handle the current for it. The TACH feature
is something you don't have to use -it just makes things more
precise if you do.
For your steering, you haven't said how large this robot will be or
what it will have to do, but a hobby servo may or may not be strong
enough. I generally don't recommend steppers as they are often
finicky and require high-current drivers and many more I/O lines
than a servo.
I think if you post an outline of what you hope to build and what it
needs to do, that people on the list will be better able to make
suggestions.
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: +403-730-8603 Fax: +403-730-8903
http://www.hvwtech.com
