Vector Compass
Miguel Purchol wrote:
>Do you have a link to the manufacturer of the compass? I could download
some
>spec sheets and take a look.
Miguel,
Here is the URL for Precision Navigation, the maker of the Vector 2X compass
module:
http://www.precisionnavigation.com/index.html
Anything you can come up with would be appreciated.
Vic
_____________________________________________________
Victor Fraenckel - The Windman vfraenc1@n...
www.windsway.com
Home of the WindReader Electronic Theodolite
Read the WIND
some
Miguel,
module:
Vic
www.windsway.com
Read the WIND
>if you got the bs2 to read fine then is it posable to
>use a bs2 to read it then transfure the data to the
>bx24?
Of course it is possible but since the results of my experiments with the
V2X will be going into a commercial product, cost is a big issue so going
this route is not viable. It supprises me that the BX24 is not fast enough
to handle the job that the Stamp can.
I will post my V2X read code today and see if anyone can come up with a
faster way to read the data out of the V2X.
Vic
www.windsway.com
Read the WIND
the basic features of the V2X including, heading, raw readings, and
calibration.
From: Victorf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PPdzZ0hwJwonKzYuXWbUPAyIh1avhw740DC6KHUPBYaich-AZ-VfH6HzwooqPnS5Aw0jRrD2KGzvf7AQbkDA]vfraenc1@n...[/url
Sent: Thursday, July 27, 2000 2:13 AM
To: Stamp Mailing List; trbrenke@y...
Subject: [noparse][[/noparse]basicstamps] Re: Vector Compass
>bx24?
Vic
www.windsway.com
Read the WIND
The Vector 2X, as I have read on the web page you point to, can output
heading data 2.5 to 5 times per second, in binary or BCD format. BCD is a
4-bit coding system for numeric output, i.e. every byte you receive contains
two numbers.
I cannot see how the BX24 would be slow to handle this, considering it's
supposed to be faster than the BSII.
In the documents it says that the heading is output in degrees, BCD format.
If we were to have a 0.1 degree resolution, then we would need four BCD
digits, i.e. four bytes.
Check your code, maybe something there.
Will keep looking at this, all the best,
Mensaje original
> De: Victorf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=225ftFk0uOwWKLOP8MH9Ox5xsXcgLG_eUxpUZt5g4pkMyQIohf4XMSfPu2Bym8IuUDkLqrnoo5JLPfu8HXg]vfraenc1@n...[/url
> Enviado el: jueves, 27 de julio de 2000 11:05
> Para: mpuchol@w...; Stamp Mailing List
> Asunto: [noparse][[/noparse]basicstamps] Re: Vector Compass
> some
> Miguel,
> 2X compass
> module:
> Thanks
> Vic
> www.windsway.com
> Read the WIND
>Vic,
>two numbers.
The serial input routine may be the bottleneck.
>Mike
Mensaje original
> > De: Victorf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7r226u8soFyeaZKqIezvsW4J-EmCOHZLOGlFxIb0CogLnGl9Q-ZXS4ntfxpIeMMAEdZAy2IEfTRdVuv1]vfraenc1@n...[/url
> > some
> > Miguel,
> > 2X compass
> > module:
> > Thanks
> > Vic
> > www.windsway.com
> > Read the WIND
Even 10 times per second at 9600 baud should be able to deliver a message
string 96 characters long ... I'm sure the Vector 2X using BCD format is not
sending 96 characters per message.
Now, what you do with the message might be holding thing up ...
-- Mitch
I beg to differ with that line of thinking. Based on my interpretation of
the reading of the Serial protocal specs for the BX-24, and which specific
ports are being used, and how they are defined, it would appear to me that
a HARD LOCKOUT condition can occur WITHIN the software (or firmware) Serial
I/O routines, IF multi-taking is occurring. Semaphores appear to be
INEFFECTIVE here.
The following makes reference to the original post which spoke of the BX-24:
Thus, it is superfluous and misleading to merely inspect the SPEED, since
NOTHING will be transmitted during a HARD LOCKOUT, and IF the HARD LOCKOUT
occurs long enough, characters may well be missed, distorted, or lost. Said
differently, a BX-24 software caused UNDER-run (aka halt) will STOP serial
transmission DEAD in its tracks. After that - who knows what might happen
down the line with the serial data feed STOPPED. Depending on WHERE it
stops and WHEN it stops, the results may be devastating, unless retry, ECC
or other forms of verification or recovery are employed; ALL of which
impact on the overall throughput. YMMV, of course.
THAT only makes matters WORSE; they were BAD to begin with, IF the stream
was halted (PARTICULARLY with incorrect Vector interfacing).
Just as a matter of note the Vector CAN be very interface timing dependent,
and likewise quite unforgiving to all but true Motorola interfaces.
Although I have seen MANY sofware interfaces, using various chips to
interface with the Vector, I have yet to see one software
routine (methodology) in any language which works 100% of the time, WITH
error detection and correction, providing full accuracy, at FULL speed,
which provides ALL of the possible Vector functions, and operates
independently using a non-Motorola microprocessor chip. ALL routines I have
seen (to date) contain some sort of concession, work-around or bypass to
the Vector (Motorola) interface, due to it's seeming (undocumented)
requirement for (near) 100% Motorola SPI compatability. Ordinary SPI
compatabilty seems to be unacceptable under certain operating conditions,
or using certain Vector programming modes. This, in over 4 years of looking
at Vector interfacing routines, and much testing on my own part <shrug>.
Personally, I view this MORE as a Motorola SPI dependence issue, and less
as a Vector compatabilty issue, since many fine operational software
routines have been written over the years. It's just not an area to be
treated lightly, or by the faint of heart. Just my own experience - yours
may certainly be different.
This very issue (HARD STOPPED serial data) has steered me away from the
BX-24, and on to other processors. For purposes and uses other than those
requiring dual-port high-spped (9600+) serial data, the BX-24 is probably a
fine product for limited multi-tasking of the sort that it does. I've never
had the need to implement such a system, and judge it's merits by the
examples, and the comments of others.
This is neither intended as a bash, nor a flame - just one person's hard
learned experiences, and continuing efforts with micro-processor interfacing.
Bruce Bates
>-- Mitch
