AC Voltmeter — Parallax Forums
AC Voltmeter
edited 2003-01-22 20:08 in General Discussion
I am attempting to build a Watt Meter. I have some basic questions
regarding the principles of the hardware design.
I was planning to measure the voltage across a resistor in series with a
load in order to figure out the current flowing to the load. Knowing the
current, I can figure out the power. The voltage across the resistor would
be fed to an A/D converter which would be hooked up to a BSII. Problem is
the voltage across the resistor will be AC. I believe I need to get the rms
voltage across the resistor in order to get a true measure of the power. If
this is so, how will I be able to get an rms voltage?
I need to be able to measure 0 - 25 A. I'd like to get as much resolution
as possible. Also, the measurement doesn't have to be real precise; I'd
like to keep the design as simple as possible. I can work with some fudge
factors here - but not too much [noparse]:)[/noparse]
Any ideas would be appreciated.
--Craig
    edited 2000-07-27 05:15
    Craig:
    If the waveform is sinusoidal, it could be peak detector-rectified. Then
    the rms value, (which is what you need for power), is peak/sqrt(2), or
    0.7071*peak. This is DC that the A/D could read. Problem is that normally
    a small value resistor is inserted to measure current, so the voltage may
    only be 1 volt or less. The diodes used for rectification would introduce
    ~0.7 volt drop, (or slightly less for a schottky diode), and also
    distortion, which makes them useless for low voltage measurement. There are
    opamp diode feedback circuits that make low level peak detection possible,
    which is probably the approach I would use. Maybe someone on this list
    knows of ICs for the job.
    Ray McArthur
    would
    rms
    If
    edited 2000-07-27 06:08
    Don't know if it is an option for you but you could use a current transducer
    with voltage output. For most of them you will need an additional power
    supply of +-15V and they'll set you back $30-$40 but you can connect the
    output directly to your A/D convertor.
    Just an option...
    edited 2000-07-27 13:36
    Craig,
    It is not too difficult to do what you want to do. The resistor idea is a
    good start. Next rectify the AC voltage with a diode. Use a signal diode,
    1N4148 or better. This will give the peak voltage at the diode output less
    the junction drop of the diode. The diode junction drop will always be the
    same, regardless of the voltage. You will have to add this value back in
    after you obtain the result from the A/D converter. You can measure the
    junction drop with a Fluke DMM or the like in the diode test mode. Once you
    have the peak value, multiply it by 0.707 to obtain the RMS value. You will
    have to write a fixed point math routine as the stamp can only do integer
    math, but that is not too difficult either. Good Luck,
    Gary
    g.shearer@v...
    G. Shearer
    Free Electron Laser Research Center
    Vanderbilt University
    Nashville, Tennessee
    To: "Basic Listserv #2" <basicstamps@egroups.com>
    Sent: Wednesday, July 26, 2000 6:43 PM
    Subject: [noparse][[/noparse]basicstamps] AC Voltmeter
    would
    rms
    If
    > --Craig
    edited 2000-07-27 16:15
    clipped from Craigs query
    Hi:
    You're missing a very basic element here. It's quite possible to have 25
    amps flowing and lots of voltage and have nearly ZERO watts!!
    You must consider the phase angle between the E and I even if you choose to
    ignore the true waveshape and assume a pure sine wave. The guru Don
    Lancaster has addressed this item a number of times in his columns. I'd
    suggest doing watt ;-) I did. Went to the power company and asked them for
    a discarded
    mechanical wattmeter like they use on your house.
    Wayne
    Wayne Roderick P.E. (EE) (ret) (NMRA life-1721)
    CEO, Teton Short Line, Pocatello Idaho, USA
    http://www.ida.net/users/tetonsl/railroad
    Note new URL- /biz/ becomes /users/
    e-mail tetonsl@i...
    edited 2000-07-27 20:25
    Craig:
    Wayne is right. I assumed a resistive load. If your load is inductive or
    capacitive, more complexity is required to account for phase angle. Also,
    if your load is nonlinear and creates a non-sine, the 0.707 doesn't apply.
    What is your load?
    Ray McArthur
    to ignore the true waveshape and assume a pure sine wave.
    edited 2000-07-28 00:31
    It's a purely resistive load (no phase difference between I and V).
    Also, I am measuring power from an outlet, so the waveform will always be
    sinusoidal and 60Hz.
    From: rjmca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JC0OOUnAisb4FX3AiXtdCNjLG2kFnpRwWQc2TiSzSFPt01Anoq6Ry2skjyjkYgno4sVZV9Zu_v3FpA]rjmca@w...[/url
    Sent: Thursday, July 27, 2000 3:26 PM
    To: basicstamps@egroups.com
    Subject: Re: [noparse][[/noparse]basicstamps] AC Voltmeter
    Craig:
    What is your load?
    Ray McArthur
    When you say rectify with the diode, do you mean I need to build a full wave
    peak rectifier with the diode?
    From: G. Shearer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=f2wQYLMTr_nvrzU3Hvy1_R3Nqoc42-NZyP9zjFwmg9ESAPFjRIfD-bbf2C8LNPl9snyoxhHyZ4JHa45QFIjoHQ]g.shearer@v...[/url
    Sent: Thursday, July 27, 2000 8:36 AM
    Craig,
    Gary
    g.shearer@v...
    G. Shearer
    would
    rms
    If
    > --Craig
    edited 2000-07-28 02:54
    Craig:
    The resistive load simplifies things. Since you should have line isolation,
    consider a current transformer. Digikey has a 1000/1, 25 amp unit for $9.
    You could rectify (full wave for winding balance) and peak detect the output
    with a cap. You would use a full wave bridge rectifier in series with a 100
    to 1000 ohm resistor on the secondary. The volts/amp output would need
    calibration because of the diodes, but it would be a simple implementation.
    Diode error would be greatly reduced by the 1000/1 turns ratio of the
    transformer. Unfortunately, diode error is not a fixed voltage as can be
    seen by looking at the V/I curve of any diode.
    Ray McArthur
    edited 2000-07-28 13:09
    Just a simple diode, half wave. This arrangement will give the peak voltage.
    Do not forget to add in the junction drop of the diode. Another point, this
    will limit detection of voltages below the diode junction voltage.
    Good Luck
    Gary
    To: <basicstamps@egroups.com>
    Sent: Thursday, July 27, 2000 6:31 PM
    Subject: RE: [noparse][[/noparse]basicstamps] AC Voltmeter
    wave
    > From: G. Shearer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KA1GMkm8UxUl6b7f9qoOhIrRMx1q2u1w6tULrf3m0_ARCbxqILMKx3nHq4y8Z9PdQ2fBnsGHCa-veVhw4CSz2XGP]g.shearer@v...[/url
    > Craig,
    you
    will
    > Gary
    > g.shearer@v...
    > G. Shearer
    > From: "Craig Lefkowitz" <craig.lefkowitz@m...>
    the
    > would
    is
    > rms
    > If
    resolution
    fudge
    > > --Craig
    edited 2000-07-28 14:15
    Ray,
    I agree that there is a V/I curve for any diode. Looking at this curve, what
    do you think the error would be for say a voltage swing of 5 volts and a
    load impedance of >1M? Using an ADC0831 or LTC1298 as the A/D converter
    would present the aforementioned scenario. Looking at the full wave bridge
    method, on any half cycle, there would be 2 diodes conducting, dropping
    voltage and introducing the errors you mentioned. Are the errors produced by
    the V/I curve significant or negligible. I would be more concerned about the
    voltage drop as it relates to the minimum detectable voltage. A peak
    detector might be in order to be able to take care of the proper sampling
    time of the ADC and at the same time, be able to scale the detected voltage
    to the limitations of the ADC. If used, the circuit would require
    calibration by taking readings at various input voltages and performing a
    linear curve fit to obtain the calibration factor. I guess it all hinges on
    what accuracy Craig requires for his project. Craig might comment on this
    point.
    Best regards,
    Gary
    G. Shearer
    Sent: Thursday, July 27, 2000 8:54 PM
    > Craig:
    isolation,
    output
    100
    implementation.
    > Regards,
    > Ray McArthur
    be
    edited 2000-07-28 20:29
    I'd like to be accurate within a half watt or so. Nothing too fancy (yet).
    From: G. Shearer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hA0vSXPsIfLxZj4OIvadyY2REFdYjl0mO1wCdd5Ltmyjujt7fANrmxZk6XkL1QsaADxXKb-PZlfmDs9YPrwlLg]g.shearer@v...[/url
    Sent: Friday, July 28, 2000 9:15 AM
    Ray,
    point.
    Best regards,
    Gary
    G. Shearer
    > Craig:
    isolation,
    output
    100
    implementation.
    > Regards,
    > Ray McArthur
    be
    edited 2000-07-28 23:33
    Gary:
    A current transformer is a weird beast; it behaves like a current source on
    the secondary when reasonably loaded. If the volt/amp numbers in the
    Digikey catalog are correct, it appears that the major losses in their
    TE1025-ND is ~2K secondary shunt, (it's 1000/1). This implies that 1.4
    volts to start conduction of 2 diodes would be developed at 0.7 amps
    primary. A diode bridge loaded with 200 ohms should provide ~0.2 volts /amp,
    which is 5 volts at 25 amps. This could be peak detected with a cap on the
    bridge output. Better performance could be achieved with a higher quality
    (bigger), transformer, but Digikey didn't list any. BTW, a full bridge is
    needed to keep DC out of the transformer to prevent saturation.
    The IC that Steve Premena suggested looks like an excellent, more complex,
    approach, but a current transformer should still be used for current
    sampling and line isolation.
    Just some thoughts,
    Ray McArthur
    what
    edited 2000-07-29 00:16
    On Wed, 26 Jul 2000 19:43:13 -0400 "Craig Lefkowitz"
    <craig.lefkowitz@m...> writes:
    > with a
    > Knowing the
    > resistor would
    > Problem is
    > the rms
    > power. If
    Ckeck out the AD637 from Analog Devices. This is a true RMS to DC
    convertor. Kinda pricey. The last bunch we bought at work set us back
    $44 each. Jameco has the older AD536 for $16 -- it may work just as well
    for your application as the AD637. These chips are essentially the guts
    behind Ohio Semitronics voltage and current xducers.
    edited 2000-07-29 01:52
    Hi Ray,
    You too Craig. Ray makes some great and very valid points. As far as the
    peak detector is concerned, a couple of op amps would improve the detection
    and provide another possible method of scaling. Horowitz and Hill go into
    great detail about the use of the op amps and the single diode peak
    detector. The diode is after the first and before the second op amp so as to
    provide a high impedance input as well as to increase the minimum operating
    voltage of the entire peak detector circuit (formerly limited by the diode.
    I guess a great question would be to have Craig enlighten us helpers on
    approximately what is the total design objective. While loving to exchange
    ideas with others, I would like to be able to properly suggest a circuit
    that would fill the bill for Craig. I guess that I am as guilty, if not
    more, than others for making asumptions as to what all of the design
    objectives really are. I have to check out the curent transformers from
    digi-key, I have to use something to monitor curent in the bias and filament
    voltages to both a klystron and thyratron operating at about the 25 MW (not
    mW) level in the newest pulse power unit that we are constructing to provide
    drive RF to a liniar accelerator. We have specified current transformers for
    the readbacks however not which ones we will be using. I will talk more
    about it if you are interested.
    Best regards,
    Gary
    g.shearer@v...
    Sent: Friday, July 28, 2000 5:33 PM
    > Gary:
    on
    /amp,
    the
    > Just some thoughts,
    > Regards,
    > Ray McArthur
    > what
    edited 2000-08-04 17:17
    >Hi:
    >a discarded
    >Wayne
    Just my 2 cents -
    Or alternatively there are pre-packaged units which might be eplored. E-Mon
    is one such solid state unit, ordinarily used for sub-metering:
    [noparse][[/noparse] http://www.emon.com/ ]
    Hope that gives you some idea as to what commerical unit offerings look
    like. No comparison presumed or inplied; just by way of example.
    Bruce Bates
    >e-mail tetonsl@i...
    I am trying to build an AC volt meter with a resolution of .1 volts. I have to
    measure 110 AC RMS. I used an RMS DC converter with an output of 1 volt being
    max. This limits the input resolution to 1 volt to the stamp. Using 1 volt
    brings the resolution to less than .001 volt DC. Would be alot better if it used
    5 volts. Anybody know a different part or another way to get the results?
    Jeff
