Futaba VFD Q
A while back there was traffic about how to interface the Futaba VFDs from
Info. Unlimited. I lost my copy of the example file...anyone want to email
it to me?
-dave
Dave Paton Motorola Advanced Technology Center
voice 847.538.7575 pager 888.773.6802
A13593@e...
it to me?
-dave
A13593@e...
'Connect serout pin to pin 33
'Pin 27 is Busy, but does not seem necessary
'and using as flow control seemed to cause problems
'J1 J2
'. . . . 1200 baud(factory)
'._. . . 2400
'. . ._. 4800
'._. ._. 9600
'Uncomment 1 of following
'Baud con 813 'T1200
'Baud con 396 'T2400
'Baud con 188 'T4800
Baud con 84 'T9600
'Serout pin is 15 here
Out15 = 1 'Set serout to high
Dir15 = 1 'and serout pin to output
pause 50 'Let settle after power up
serout 15,Baud,[noparse][[/noparse]31] 'Reset
serout 15,Baud,[noparse][[/noparse]17] 'Normal mode(18 for scroll mode)
'Line 1, position 0-19
' 1111111111
' 01234567890123456789
'Line 2, position 20-39
' 22222222223333333333
serout 15,Baud,[noparse][[/noparse]"This is line 1
serout 15,Baud,[noparse][[/noparse]16,20] 'Goto position 20
serout 15,Baud,[noparse][[/noparse]"This is line 2
end
***** This is from a later email from Mike DeMetz:
> Best, Duncan
Yes I figured out the jumpers were backwards. Working fine at
9600(J1&J2 shorted). Have not tried it on a BSI(at lower bauds) yet.
When I had OUTx=1 after DIRx=1 I would get a glitch character in
position 0 on Reset. Switching around seemed to fix that. Without
the Pause 50 before sending the first data, I would get some
garbage and text starting at the wrong place on power up
occasionaly.
Enjoy,
Ray McArthur
To: 'stamp list' <basicstamps@egroups.com>
Sent: Tuesday, July 25, 2000 7:38 PM
Subject: [noparse][[/noparse]basicstamps] Futaba VFD Q
> it to me?
