Brand new BS2 doesn''t work
Cameron:
If you've tried everything as you say, yes the stamp could be defective.
Although this is unlikely. It's more likely that you missed something, like
a jumper or something like that.
Is there any way you could borrow another stamp? You could swap it out and
prove it one way or the other. Did you buy it over the counter? Just take it
back to the store. If it's mail order, that's a problem.
Good luck!
Craig Latta
To: <basicstamps@egroups.com>
Sent: Sunday, July 23, 2000 10:39 AM
Subject: [noparse][[/noparse]basicstamps] Re: Brand new BS2 doesn't work
> Thanks for the advice. Unfortunately, everything you suggested checks
> out and it still doesn't work. Ive tried swapping serial cables, and
> checking voltage to chip, which is always exactly at 5 volts. Im
> using the board of education, so the power wiring is preset. Does
> this suggest the stamp is defective?
> Thanks, Cameron
Good luck!
Craig Latta
> Thanks, Cameron
