Need more help on programming
Hi!
I am suppose to come up with a program for this robot using a basic
stamp. The problem is that time is rather short(like within this week
or else.....*sigh*) and i haven't got the time to really understand
the full usage and language used by the basic stamps.
Details of the robot:
The function of this robot is to only move in the presence of light
(hence there is a light sensor) and this will cause the 2 stepper
motors (it should be the unipolar kind, has 4 outputs to each motor
directly) to start moving.
There are 3 IR sensors (the front, left and right)and they are to
prevent the robot from hitting any obstacles.
I don't know how should i loop the program so as to make sure that
the controller will keep checking for the presence of light.
Actually, i am hoping someone will be able to give me a clearer
picture of how the program should be written for the robot with the
above function. The controller seems to be able only to do one thing
at a time.By the way, the controller i am using is Basic Stamp I.
Thanks for reading this!
hope to hear from all of you soon [noparse]:)[/noparse]
Joanna
Al Williams and Andrew Tucker: Thanks for replying to my previous
postings....wonder if you two will read this as well......
Joanna
' do one-time init code here
top:
gosub checklight ' set light on variable to 1 if light present
if lighton=1 then goto top
gosub findobstacles ' set left, fwd, right to 0 if blocked
if fwd=1 then gofwd
if left=1 then goleft
if right=1 then goright
gosub goreverse
' fall into goright
goright:
' make steppers move right
goto top
gofwd:
' make steppers move forward
goto top
goleft:
' make steppers move left
goto top
goreverse:
' make steppers back up
goto top
checklight:
' set lighton
return
findobstacles:
' set variables
return
Something like that. The Stamp I doesn't have much memory compared to the
Stamp II, so I hope it will all fit.
If the light sensor is a CdS cell (like a circle with a snake running
through it) you'll use the POT command to read it (and you'll need a
capacitor). If it is a photodiode (like a little transparent transistor)
you'll just read it as a digital input (pinX where X is the pin number).
Most likely you have one of these two.
The IR sensors are trickier. You'll need to excite an IR source at the
proper frequency that the detectors use. This is often done with a 555 timer
or similar oscillator and is often at about 38kHz (for historical reasons).
The sensors then usually have all the filtering etc, so you can just read a
digital output.
You might find the BOEBOT documentation on the Parallax Web site useful.
Al Williams
AWC
* Microcontroller Projects with Basic Stamps:
http://www.al-williams.com/awce/sbook.htm
> From: Joanna [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0Yo6f2c0dWnR13V3HPlOefKjk8dBX-NAbfuKONEh-3b5uE7beywAHgw2ODR7uW6gAkQlWSZw-VE8aSj4]qiuyi18@h...[/url
> Sent: Sunday, July 23, 2000 12:33 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Need more help on programming
> Hi!
> Joanna
