Keypad encoder problem MEMKey (second post)
Hi all,
I'm trying to use the MEMkey keypad encoder (from Solution Cubed) with a
BS2SX.
I can communicate with the MEMkey, I even receive codes when I push a button
on the keypad.
The problem is that I can't program the keys to return certains values. It
should be possible, because there is a code sample in the little manual of
the MEMkey.
Also, the encoder should return codes from '00'H to '13'H (or 0 to 19) for
the keys 0 to 19 (this is the factory setting). But I get results like 127
for the '2' key, 63 for the '3' key, and so on.
The following code is not working :
N2400 con $43FD '2400 baudmode for BS2SX
SEROUT 14,N2400,[noparse][[/noparse]$0A,$00,$40]
PAUSE 10
This should program the encoder to return '40'H when the key 0 is pushed
(which is the '1' key on the keypad I use).
Is there a trick for the BS2SX, or do I forget something else ?
The keypad is a 4 x 4 matrix from Grayhill.
Thanks in advance for your help !
Phil.
Philippe Derenne
Computer Solutions
Belgium
mailto:derennep@s...
BS2SX.
on the keypad.
the MEMkey.
PAUSE 10
Phil.
Philippe Derenne
Computer Solutions
Belgium
