20*log(a/b) caculation
I have a application of calulating LOG function, I know PAK-2 math co-processor
can do this, How
do I connect this PAK 2 with BS2 ? After calulation I need send out to 16*1 LCD
. Is there anyone
help me out ? I have some experience of BS2, but how the BS2 know floating
point math when I
connect PAK2 ?
Sorry ! I have no idea of PAK2 .
TIA
Baker
can do this, How
. Is there anyone
point math when I
connect PAK2 ?
TIA
Baker
how to interface to a stamp or pic, both look very easy and straight
forward.
Norm & Monda
Cozy MK IV #202
Ford V-6 Powered
To: <basicstamps@egroups.com>
Sent: Thursday, July 20, 2000 8:45 PM
Subject: [noparse][[/noparse]basicstamps] 20*log(a/b) caculation
co-processor can do this, How
16*1 LCD . Is there anyone
floating point math when I
> connect PAK2 ?
> TIA
> Baker
page that shows some ways to do logs within the restraints of the stamp's
integer math:
http://ourworld.compuserve.com/homepages/emesys/BS2index.htm
Best, Duncan
provide a small library that allows you make calls like:
gosub floadx
gosub flog
To do the work. Sending the data out to the LCD could be done using the
fdump command (changing debug to serout -- assuming a serial LCD) or you
could convert it to an integer (FInt).
You can find the manual and many examples in the document library at
http://www.al-williams.com/awce/doclib.htm
Al Williams
AWC
> From: baker_bai@c... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bNzKDEY7o7KHr3QZWKIa6ld4tDhwF_r9fjTgScZf0Y8gzB8Fs9T8gxnaEsBLeXr-km-j8jQaa7t5uTenFw]baker_bai@c...[/url
> Sent: Thursday, July 20, 2000 7:46 PM
> To: basicstamps@egroups.com
> math co-processor can do this, How
> out to 16*1 LCD . Is there anyone
> know floating point math when I
> connect PAK2 ?
> TIA
> Baker
