BS2 problem centering servo
Page 11 of Robotics! Student Workbook (ver 1.2) instructs me to
center the servos (after removing the stops on the servo gears) by
programming this in my PC:
center:
pulsout 15, 750
pause 20
go to center
I did this but the servo spins without stopping. (To stop the servo
I must delete the pulsout line and Alt-R again, or insert Sleep and
Alt-R again. When I change from Servo 1 to servo 2 (pulsout 3,750)
then servo 2 spins endlessly.
Apparently the program is not even getting to the pause statement
because I can remove "pause 20" and "go to center" and the same
result occurs.
Any clues as to what I've done wrong? I've double checked my wiring
and it matches the illustration on page 15 of Robotics! Student
Workbook. Any help is gratefully appreciated.
Don Wade
center:
pulsout 15, 750
pause 20
go to center
result occurs.
Don Wade
Just a guess, but if you've taken out the stops and the resistor gear,
"center" really means stop. So run your program as you have there and then
adjust the pot on the servo until the servo is still. So think of it as
centering the pot, not the servo shaft.
Al Williams
AWC
* Control 8 servos at the same time:
http://www.al-williams.com/awce/pak8.htm
> From: dwade@d... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bfdidIzl674MrfISMtdoAMiRzYZmVVfhWt3Z0C5Q4C4CLTDlmrg3tM-8X6OuSGBTKvifU3pTrTU]dwade@d...[/url
> Sent: Wednesday, July 19, 2000 10:20 AM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] BS2 problem centering servo
> center:
> pulsout 15, 750
> pause 20
> go to center
> result occurs.
> Don Wade
something like this.
Load that program (you are correct)
The servo will start to spin.
As it is doing so adjust the internal pot in the servo until the servo
stops. This is how you know the pot is now set to 750.
Once this calibration is done then when ever you want to stop the spinning
servo use pulsout pin, 750, when you want it to go use any number between
500-749 for one direction and 751-1000 for the other direction. The farther
away from 750 the number is will make it spin faster. Sort of like a built
in speed control.
I haven't tried this yet, but I did read that manual, and that is what I got
out of it. If it doesn't work, then maybe someone else here will be a
better help.
Shawn
From: dwade@d... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kF3My_2aCv2AirAQdkbRFNcyr3z-w_QXwXchThLLJ8WLZt-1JrVOD7yLLKAPDr3wKRFe3RfG]dwade@d...[/url
Sent: Wednesday, July 19, 2000 8:20 AM
center:
pulsout 15, 750
pause 20
go to center
result occurs.
Don Wade
What I ended up doing was trial and error
values until I found ones that worked.
Bob
>center:
> pulsout 15, 750
>pause 20
>go to center
>result occurs.
>Don Wade
