Object Tracking - was:Dual-axis solar tracking code
Hello All,
I am working on a project in which I need to track an object.
I need to create an object (perhaps electronic pendant) for someone to
carry or wear.
Then I need to create a tracker to constantly keep this object centered
in its "field of view".
A very simplified example would be a spotlight that would be controlled
by the tracker to constantly keep the light shining on the moving
subject.
Any ideas?
Perhaps something like a solar tracker, but instead track an infrared
led?...a radio signal? HELP?
Rus
Rus Hardy
"Lucky Devil"
Keeper of the Bucky-n-Thrifty Flame
http://www.boneyardbargains.com/
"my mind wanders....I'm just along for the ride"
carry or wear.
subject.
Any ideas?
Rus
Rus Hardy
"Lucky Devil"
pattern optical tracker. Camera have a RS232 serial communications that
could be interfaced with external components. Look at the professional
Sony web site for more.
ACJacques
Rus Hardy wrote:
> Hello All,
> carry or wear.
> subject.
> Any ideas?
> Rus
> Rus Hardy
> "Lucky Devil"
Systems that you describe already exist. They are called "tracking follow
spotlights" and companies like Martin
http://www.martin.dk/general/frontpage.asp
make three types: Lighting Director, SoloSpot, and TrackPod.
As, you are probably NOT in the market to buy such a system, and you are
developing something similar, perhaps you can get some information from them
as to how their systems work in order to complete your project.
Jim
> From: Rus Hardy
> Reply To: basicstamps@egroups.com
> Sent: Wednesday, July 12, 2000 8:11 am
> To: Stamp List
> Subject: [noparse][[/noparse]basicstamps] Object Tracking - was[noparse]:D[/noparse]ual-axis solar tracking
> code
> Hello All,
> carry or wear.
> subject.
> Any ideas?
> Rus
> Rus Hardy
> "Lucky Devil"
> Rus,
> Jim
> > From: Rus Hardy
> > To: Stamp List
> > code
> > Hello All,
> > carry or wear.
> > subject.
> > Any ideas?
> > Rus
> > Rus Hardy
> > "Lucky Devil"
Actually, the spotlight was just an example. However, I will check their site
for info. Thank you!!
Checked the site.....can you say expensive!!!! This is similar to what I need
to do.
Incredible precision is not what is needed here.
This will be used in an animatronic application to keep the animatronic facing a
person or object ans the person or object moves.
I am sure there has got to be some robotics application out there where the
robot steers its way toward a moving object.
All I need to be able to do is stay facing the proper direction.
Rus
Rus Hardy
"Lucky Devil"
facing a
Kevin Ross of the Seattle Robotics Society designed a low resolution vision
system that can do this. Check the Jan. 97 issue of the SRS newsletter:
http://www.seattlerobotics.org/encoder/jan97/lowresv.html
Best, Duncan
