I/O''s
--- In basicstamps@egroups.com, "Dave McCormick" <MACKRACKIT2@p...>
wrote:
> Hi,
> I am working on a project that needs ten outputs and eleven inputs.
> How can two stamps be coupled to do this.
> Thank you,
> Dave
Dave,
Depending on what you need to do with the outputs, it may be as
simple as adding one or more serial-in parallel-out chips. This will
give you 8 or 16 or more outputs from 3 pins. As Al Williams pointed
out, there are a number of co-processor solutions available which are
more expensive (but less than an additional Stamp), but which off-
load complex output functions from the Stamp and let your Stamp
program spend more time on inputs. We have a variety of these
available, as do several other vendors, depending on what kind of
outputs you need to drive.
Chuck Davis
Oak Tree Systems
www.oaktreesystems.com
wrote:
> Hi,
> Thank you,
> Dave
Dave,
Chuck Davis
Oak Tree Systems
