I/O''s
A pretty simple method would be to use a couple octal latches, such
as the 74HC373. The stamp could control which latch was active to
pass though 8 bits at a time, then switch to another.
This is known as multiplexing using tri-state logic by the way.
-Martin Hebel
SelmaWare Solutions
www.selmaWare.com
Electronics Managament, Southern Illinois University
www.siu.edu/~imsasa/elm
--- In basicstamps@egroups.com, "Dave McCormick" <MACKRACKIT2@p...>
wrote:
> Hi,
> I am working on a project that needs ten outputs and eleven inputs.
> How can two stamps be coupled to do this.
> Thank you,
> Dave
-Martin Hebel
SelmaWare Solutions
www.selmaWare.com
wrote:
> Hi,
> Thank you,
> Dave
