homemade carrier boards again
Photo sensitized boards, fairly inexpensive: Kepro, St. Louis, MO
800-325-3878.
If anyone has a better connection for these boards, especially
two-sided, please reply also.
From: LJGeib@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RKKrdqF-6X8J9wfKR8DKeB8cI84jxUPbzvHneXxTQ6ZcfblC3c9T4nrhmZ-vmF4KtqkwxJE-PwEG]LJGeib@a...[/url
Sent: Tuesday, July 04, 2000 12:48 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] homemade carrier boards
Kerry-
Maybe you could post a. Gif and we could etch our own boards.
In a message dated 7/4/00 8:31:34 AM, admin@m... writes:
>I have seen the discussion going on about homemade carrier
boards. I have
>designed a circuit board for Phil Andersons home brew stamp
kit.It also
>has
>onboard room for a 555 timer to drive IR output,outputs for
all 16 stamp
>pins,db9 serial plug,power supply plug ,reset switch,power
switch and 3
>outputs for standard servos,being driven either directly off
the stamps
>output power or thru the onboard 5 volt regulator,plus 1"x2"
of drilled
>lands wired as a breadboard for prototyping. All on a 3x4 form
factor.
> Originally I made this just for my own use,but I could make
some for a
>few
>people if they wished,however I cannot find a source for
inexpensive photo
>sensitive pc boards
Larry
ljgeib@a...
800-325-3878.
Kerry-
boards. I have
kit.It also
>has
all 16 stamp
switch and 3
the stamps
of drilled
factor.
some for a
>few
inexpensive photo
>sensitive pc boards
Larry
ljgeib@a...
