homemade carrier boards+
Thanks guys..
last night I actually wired up a small pcb with a socket for the bs2 and leads
for all the i/o pins..
I used an old com port from a pentium mb for communications..
this way, I can use more of my breadboard..
I do have a few questions though..
can I set up a switch for the reset, the same as for an i/o pin?
(1k resistor to keep it high until the switch grounds the pin?)
unregulated voltage? can I just hook up a 9v battery + to this pin?
what kind of heat will this generate? or should I just go with a 7805 and some
caps to the regulated +5v pin?
Thanks!
Sean
Thanks!
Sean
*** Yes
*** NO! Use regulated 5 volts to avoid smoke.
some caps to the regulated +5v pin?
*** A 7805 should work.
Good luck,
Ray McArthur
(http://members.aol.com/rich924/html/bs2.html)
On Tue, 4 Jul 2000, Sean Conlon wrote:
> Thanks guys..
> Thanks!
> Sean
Where do you get the sip sockets? I've been looking around for them
for a while and the RSs near me don't have anything close..
Sean
from All, Hosfelt, jameco or RadioShack online.
-Rich
On Thu, 6 Jul 2000 gnomish1@p... wrote:
> Cool..
> Thanks
> Sean
