Potentiometers
Archiver
Hi all, Im new to the group so Im sorry if this topic has been
covered. Im trying to control serveral servos using a SSC2, driven by
a BS2, which is reading several potentiomers. Sounds straight forward
until I try to read from the pots. Im using the resistor/Cap method
in the BS manual, but arent havent any luck. Im getting a reading of
0 from the pot until I touch the pot then it goes beserk, when I turn
the pot I get no responce.
Am I better off using a BS1 and using the POT command ?. Is there an
IO expander for the BS1.
I'd really like to get the BS2 working as I've already bought it. Any
help would be greatly appreciated. Thanx in advance.
RXC
RXC
serial ADC. Maxim makes excellent ones and stamp code for interfacing them
is available. Check out the MAX187 and 186 at:
http://www.maxim-ic.com
These folks also have an outstanding free sample policy 8^]
Best, Duncan
Can anyone draw me a simple circuit to give me an idea on how to use a ADC
in the circuit.
Regards
RXC
From: orthner@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LtnIZ-GSfBw7uIbcaND_8JnIx04nTomWE-ZmFI1nIrz0CxdUpc-JTufuexZlsenTMYLciwD83lLNpDWF3lnd]orthner@s...[/url
Sent: Wednesday, 5 July 2000 3:32 a.m.
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Potentiometers
The POT command has it's limitations. A better solution might be to use a
Best, Duncan
>So if I go down the ADC path, is this going to take less effort than RCTime.
>in the circuit.
The hookup is simple and will be clearly shown in the datasheet for the
device, which can be D/L'd from the Maxim site. The code is only a few
lines - I can't say whether this is 'less effort' or not...For using pots
to drive seros via pulsout I've always found RCtime to be inadequate - not
enough resolution and too slow. But if it works for you - go with it 8^]
Best, Duncan
how to program it so it can read what it's set at.
Thanks.
question has allready been answered, there are some good examples around,
plus the RCTIME command as shown in the stamp manual is worth a look.
Chris
Sent: Sunday, April 01, 2001 11:17 AM
Subject: [noparse][[/noparse]basicstamps] potentiometers
> I need to know how to hook up a potentiometer to my Basic Stamp2 and
> Thanks.
Activity Board. It shows you how to hook up a pot and how to read it.
Most of what I picked up on using my Basic Stamp has been scamming stuff off
their web page. Lots of useful stuff there if you take time to poke through
it.
sjohns10@hotmail.com writes:
Take a look at the description for RCTIME in the Stamp manual. ·In that
section you will find the schematic for connecting a pot to the Stamp.
[/font]
analogue potentiometer, any suggestions? Thanks!
wrote:
> Hello, im having trouble finding a way to read the value of an
Binky, Use a BS2 module at least, and look in the pbasic syntax guide
under RCTIME command.
Other documents you might like are available at www.parallax.com
C.C.
<captainconstructor@y...> wrote:
> --- In basicstamps@yahoogroups.com, "blinkersrulez" <binky7000@a...>
guide
> Regards,
> C.C.
When I try to use the RCTIME with my BS2sx all I get is either 1 or 0
any ideas? Thanks for your help!
available in hard-copy format, but they are also available online here:
http://www.parallax.com/html_pages/downloads/basicstamps/documentation_basic_sta\
mp.asp
The reading of the value of a POT is a very good first project. I suggest
you RTFM (Read The Fine Manual) and then, if you still have questions,
post your code and results of your experiments, and I'm sure everyone
will be happy to help you. Not trying to be obstinate, just trying to
adhere to good proverbs:
"Give a man a fish, and you feed him for a day. Teach a man to fish, and
you feed him for life."
or:
"Build a man a fire, and he's warm for a day. Set a man on fire, and he's
warm for the rest of his life." [noparse]:)[/noparse]
Vern
PS: Cant take credit for the above, got it from here:
http://www.halfbakery.com/idea/Give_20A_20Man_20A_20Fish_2e_2e_2e
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
vern@t... www.txis.com | is up, then we obviously don't need
Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
> Body of the message will be ignored.
0
Can you post the relevant code and schematic?
Without them...
In no particular order...
If you forgot to discharge the cap before issuing rctime you will get
a 1 result...If your variable is bit-sized (should be word) you would
only get a 0 or 1 result...the component selection/hook-up may not be
correct.
Jamie says "Hmm...could be anything!"
C.C.
