signal interfacing
Hey All:
I have a circuit that uses a 555 timer with a 5k pot to control it. I need
to interface a 2.5 - 5 volt dc voltage to change the resistance of the main
5K pot. (Like a voltage controlled pot in series with the 5k) The goal is to
use the varying voltage to control the 555, but also to keep the 5K pot as
an overall range adjust. I know this is off topic, but I do plan on
converting to a Stamp circuit eventually. Any help is much appreciated!!
-Steve Chlupsa
-Steve Chlupsa
A Jfet or small mosfet in series or parallel with the pot. Scale the 2.5 to
5 volt signal to modulate the fet to desired resistance.
Ray McArthur
main
to
You might be able to modulate the 555 pin 5 reference voltage instead. A
series resistor may be the only required interface...
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
Thanks!
I'll try that.
-Steve
To: <basicstamps@egroups.com>
Sent: Monday, July 03, 2000 2:42 PM
Subject: Re: [noparse][[/noparse]basicstamps] signal interfacing
> Steve,
need
main
to
as
Thanks!
I'll try that.
-Steve
Sent: Monday, July 03, 2000 12:09 PM
> An offhand idea:
to
> Ray McArthur
need
> main
is
> to
as
