lm317 regulator
I am using lm313 to drive the following
BASIC stamp OEM, lt1298, NE555 Timer, Nand Gate, Frequency to voltage
converter, Interval timer.
I am feeding the the regulator from a nine volt battery and it is producing
5.2 volts. The I.C is getting warm. It is not heat sinked.
Is it normal for the I.C to get warm or is it that some thig is wrong?
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
will last very long
is the lm313 a 5 volt reg - if it is I would worry why it is 5.2v rather
than 5.02
richard
To: <basicstamps@egroups.com>
Sent: Friday, June 30, 2000 10:56 AM
Subject: Re: [noparse][[/noparse]basicstamps]lm317 regulator
producing
voltage as heat like a simple resistor. It is built-in with temperature
protection. Difference from input voltage - output voltage will be
transformed in heat.This is not efficient. The 9 volt battery will
quickly be empty.
Switching regulators (DC-DC converters) are more efficient, but more
complicated and expensive.
ACJacques
output set by external resistor?
If so, you can make any voltage you want, up to nearly the Vin.
From: fernando hood [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eszEClNdsHlm864sxvdmb97vnxSFkKV4689VxbAjbsl8DbLKApPldTrMz563TarKS1HF2PhNkVhBAFoaTg]hoodey@h...[/url
Sent: Friday, June 30, 2000 11:57 AM
To: basicstamps@egroups.com
voltage
is producing
wrong?
_________
it to the IC's specs..
>From: "A.C.Jacques" <acjacques@i...>
>Reply-To: basicstamps@egroups.com
>Date: Fri, 30 Jun 2000 16:19:29 -0300
>Linear regualtors like 78XX and LM317 will dissipate exceding
>quickly be empty.
>ACJacques
>producing
