Input Timing....
Tim-
The Stamp innards are optimized to look at specific groups of
I/O pins (e.g. P0-P3, P0-P7, P0-P15) very efficiently with the
INA, INL, INS, etc. predefined variables. Read up on them (and
their OUTx brethren) for a description. For example, a tight loop
such as
waitForHigh:
IF INA = 0 THEN waitForHigh
will detect any of I/O's 0 thru 3 going high, but will also hold your
Stamp's program at this point until one or more does go high. In
this example, the inputs are checked approximately four times each
millisecond, which may allow more than one input to go high between
samples. If you need a shorter sampling interval to achieve greater
which-went-first resolution, you'll need some external logic.
Steve
On 24 Jun 00 at 15:14, Tim and Jo wrote:
> ...I have several logic inputs to a Stamp II and I'd like to be
> able to tell which input goes high or low first. The problem seems
> to me that if the program is run sequentialy, how are all of the
> inputs checked at the same time?
such as
waitForHigh:
Steve
main:
If INA <INB then x......
If INB <INA then y....
goto main
To: <basicstamps@egroups.com>
Sent: Saturday, June 24, 2000 9:11 AM
Subject: Re: [noparse][[/noparse]basicstamps] Input Timing....
> Tim-
> such as
> waitForHigh:
your
> Steve
seems
I know that many of you must have worked through this problem before and
I'm hoping that you can help out. I have several logic inputs to a Stamp II
and I'd like to be able to tell which input goes high or low first. The
problem seems to me that if the program is run sequentialy, how are all of
the inputs checked at the same time? I know that a Stamp II is fast, but
it's still running the program one line at a time. Is there a simple
solution to this? Can an input buffer simular to the Mem Key module sort
this out, store the input timing information and then report back to a
Stamp, or am I missing something basic and making this more difficult than
it needs to be? Any help with your experiences would be much appreciated.
Tim
