Newbie - BS2 has never responded to pbasic editors
I've searched the list and can't seem to find a clear answer to this
one.
I can't get my BS2 to respond to the pbasic editors.
Here is what I've tried and think I know.
1) I've used 3 computers (1 was a laptop which I hear can give
problems). I am not in a DOS box of windows when using the DOS version
of the editor.
2) I've tried the Windows version of the editor.
3) I've called parallax tech support to verify that I've wired the BS2
correctly. (4 serial lines, power and ground 9V).
4) Checked the battery.
5) I am getting a steady 5V on the output (forget what the pin is
called).
6) I think the serial cable is wired correctly for the loop back
because the windows pbasic editor recognizes the port but can't get a
response from the BS2.
Any suggestions? Is there any way to determine if the BS2 is alive or
burned out?
Thanks in advance,
Ron Johnson
one.
of the editor.
called).
burned out?
Thanks in advance,
Ron Johnson
-William
To: <basicstamps@egroups.com>
Sent: Friday, June 23, 2000 2:16 PM
Subject: [noparse][[/noparse]basicstamps] Newbie - BS2 has never responded to pbasic editors
> one.
version
> of the editor.
BS2
> called).
> burned out?
> Thanks in advance,
> Ron Johnson
help everyone who is attempting to help!
Ron
--- In basicstamps@egroups.com, "William Cox" <william@c...> wrote:
> What error are you getting?
> -William
> From: Ron Johnson <rojohnson@d...>
editors
to this
> > one.
give
DOS
> version
> > of the editor.
wired the
> BS2
pin is
> > called).
back
can't get a
is alive
> or
> > burned out?
> > Thanks in advance,
> > Ron Johnson
-William
Sent: Monday, June 26, 2000 12:26 AM
Subject: [noparse][[/noparse]basicstamps] Re: Newbie - BS2 has never responded to pbasic
editors
> I'm getting the standard "Hardware not found". That would probably
> Ron
> > -William
> editors
> to this
> > > one.
> give
> DOS
> > version
> > > of the editor.
> wired the
> > BS2
> pin is
> > > called).
> back
> can't get a
> is alive
> > or
> > > burned out?
> > > Thanks in advance,
> > > Ron Johnson
