Very confused.
Hello!
I have a problem understanding your text. On page 10 of "what's a
Micro controller?" you have a circuit that have a LED
and a resister hooked up to the basic stamp. The confusion is on page
15. It states in the third paragraph that the
current flow is from "+voltage through the resister, LED, and into
the stamp P(0) pin. Looking at the schematic in figure
1.6 pictorial, that seems incorrect. It is saying that current flow
is from +voltage through LED, and into the resister
then to the stamps P(0) pin. This is very confusing to me. Could you
clear that up. I tried to think that the stamps P0 pin was sending
the current, but that still doesn't sound right. Please help me
understand what's going on.
P.S. look at the pictorial on page 24 figure 2.2. The LED and
resister is reversed. I don't understand.
Robert P
Robert P
In the electronic world there are two ways to thinks about
electricity, and this is usually the source of the confusion.
Positive electricity flows from + to - and follows the little arrows
on semiconductors as shown on schematics. (hole flow)
Negative electricity flows from - to + and is opposite of the little
arrows on semiconductor schematics. (electron flow)
IF you keep this in mind and the previous information on Logic levels
and the sinking vs. sourcing of current, the confusion will be very
clear. It may seem like mud now, but it gets better!
Ron
To: <basicstamps@egroups.com>
Sent: Friday, June 23, 2000 12:42 PM
Subject: [noparse][[/noparse]basicstamps] Re: Very confused.
> --- In basicstamps@egroups.com, Robepark1@j... wrote:
> > Hello!
> page
flow
> you
> > Robert P
> Robert,
> Without looking at the diagrams you referenced (I don't have them
> handy) I can tell you that the outputs of the Stamp (and most
> microcontrollers) are designed to either "source" or "sink" current.
> Sourcing simply means that if the output is high (5 volts, or
logical
> 1), current will flow out of the pin, through a load (resistor, led,
> whatever), to GROUND. In this case the pin is wired so a logical 1
> output turns on the current to the load. Sinking means that when the
> output is low (0 volts or logic 0), current can flow from and
> external 5 volt source, through the load, into the pin - in effect,
> the pin acts as the ground. In this case, you set the output to zero
> to turn on current through the load. You will see examples done both
> ways, depending on how the external circuitry is connected. Neither
> is incorrect, it's just a matter of what you are trying to do.
> Many ICs built to drive LEDs or other loads such as motors, may only
> sink or only source current, although some can do both (these are
> usually referred to as a "Half Bridge").
> Hope this helps a little.
> Chuck Davis
> Oak Tree Systems
> www.oaktreesystems.com
> Hello!
page
you
> Robert P
Robert,
Sourcing simply means that if the output is high (5 volts, or logical
Chuck Davis
Oak Tree Systems
through the book as well, but as you said, I found examples both ways. I
prefer to have it "source", it seems to make more sense in the program to
have the high be on and the low be off. I did figure it could work either
way, but it was nice to your explanation as why. It has finally "clicked"
in my mind how it actually works!
Thank you Chuck!!!!!!!!!
Shawn
From: Chuck Davis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0_YwhCMjc-zsYM-xcXcAMlRVtFR6YT_fuIdpftYL5g1S8JWK7eAzHAZD3tOcc_66ej-MFCztuWPXwgnK2w-ADoPbPnw]cdavis@o...[/url
Sent: Friday, June 23, 2000 5:42 AM
To: basicstamps@egroups.com
> Hello!
page
you
> Robert P
Robert,
Chuck Davis
Oak Tree Systems
