C/C++/Java Stamp
If this was the case it would no longer be the "basic" stamp, it would be
the "java stamp" or "C++ stamp."
From: ttm@g... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0NxcKREqYu6Qk0i1fgTl59jOkrkW2YEaeaHaz--Q-1h35-cE45r-xkGQaLk6bl1GT5Fjwg]ttm@g...[/url
Sent: Thursday, June 22, 2000 2:52 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] C/C++/Java Stamp
Do any of you know if there are any plans to build a stamp you can
program in any of the above languages???
Thanks!!!
Thanks!!!
Thanks!!!
-William
To: <basicstamps@egroups.com>
Sent: Thursday, June 22, 2000 5:51 PM
> Thanks!!!
question...
would be
> From: ttm@g... [noparse][[/noparse]mailto:ttm@g...]
> Thanks!!!
the divice. If you want to program in C or C++ or
Java or Pascal or Forth or PLM or . . there are a few
more, all you need to do is aquire the compiler and
code away. All these language tool are available for
PIC, Atmel, Scenix, and any other micro you are
interested in. And you get the added advantage of
coding in assembler, as this is what these tool code
to. If you are interested I can give you a list of sites
where the best tools are located.
cheers
kdanner@s...
$50 that has Java JVM and can support servlets. It comes with a free JDK for
board.
Murray
Sent: Thursday, June 22, 2000 5:49 PM
Subject: [noparse][[/noparse]basicstamps] Re: C/C++/Java Stamp
> Yes i know that, but it seems you missed the entire point of the
> question...
> would be
> > Thanks!!!
with the new software the web server servers applet/jar file to the
browser and
you get real time weather data served to the browser.
You need to bootstrap the board from the serial port. My NR machine is
quirky with it, but my 95 machine is fine. After that you can use the
ethernet interface. I have a cable modem and want to set everything up so
that I can get the weather data from the net. I fly RC airplanes and the
field is near my house.
-Rich
On Fri, 23 Jun 2000, Murray Snowden wrote:
> Try http://www.ibutton.com/TINI/index.html This is a web server board for
> board.
> Murray
> From: <ttm@g...>
> > question...
> > would be
> > > Thanks!!!
William Cox wrote:
> Try to OOPic. - www.oopic.com
> -William
> From: <ttm@g...>
> > Thanks!!!
-Rich
On Fri, 23 Jun 2000, jhodges wrote:
> who cares
> > -William
> > From: <ttm@g...>
> > > Thanks!!!
