KeyPad Data
I have a 16 key keypad attached to my stamp through a 74c922 decoder.
Here is my problem. I need to enter a numer from the keypad: Example
85 and store that number in to a varible.
How do I write software that will alow me to enter more then one
number and put the that combination into one var.
Right now i press one key to increase the number and an other to
decrease the number then that total will be stored into a var.
Thanks!!!
Tobin M.
Thanks!!!
Tobin M.
0 and 200.
Thanks anyway!!!
Tobin
--- In basicstamps@egroups.com, "Mohamed REFKY" <refky@h...> wrote:
> This is also what I want to do,her is my idea:
> Take the first number 8 and multiply it by 10 then add it to 5 you
get
> 85.When You press a third number for example 2,take the last valu
85 and
> again mupltiply it by 10 then add it to 2 you get 852.
> So you always take the key value and add it to the last value
mualtiplied
> by 10.First Number must not multiplies by 10 unless Basic Stamp
receives
> the secnond number 5.
> Regards
> Mohamed REfky
> >From: ttm@g...
> >Reply-To: basicstamps@egroups.com
> >Subject: [noparse][[/noparse]basicstamps] KeyPad Data
> >Date: Wed, 21 Jun 2000 23:12:08 -0000
decoder.
Example
> >Thanks!!!
> >Tobin M.
______________________________________________________________________
__
> Get Your Private, Free E-mail from MSN Hotmail at
http://www.hotmail.com
Mohamed's reply was correct. Take the following code for example...
Buffer var byte
Key var byte
Buffer = 0
Main:
' Get your key value and store it in "Key"
Key = [noparse][[/noparse]Key value]
' Shift Numbers in Buffer one place to the left
' And add your last key value
Buffer = Buffer * 10 + Key
Goto Main
When you start the program Buffer is set to 0. Now lets say you press the
key "1"
Buffer = 0 * 10 + 1
so
Buffer = 1
The value in Buffer now equals 1. Next you press "2"
Buffer = 1 * 10 + 2
so
Buffer = 12
And just to prove it works for zero..
The value in buffer is now 12 and you press "0"
Buffer = 12 * 10 + 0
so
Buffer = 120
The only limitation to this code that I can see is that you can't have
leading zeros (002 for example), but it should work for your values of zero
to 200.
Jared
Electrolinx - http://www.geocities.com/electrolinx/
VB Overdrive - http://extreme-vb.net/vboverdrive/
To: <basicstamps@egroups.com>
Sent: Thursday, June 22, 2000 10:32 AM
Subject: [noparse][[/noparse]basicstamps] Re: KeyPad Data
> That number was just an example, i need to enter any numbers between
> 0 and 200.
> Thanks anyway!!!
> Tobin
> get
> 85 and
> mualtiplied
> receives
> > Regards
> > Mohamed REfky
> > >From: ttm@g...
> decoder.
> Example
> > >Thanks!!!
> > >Tobin M.
> __
Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
so that when that key press is detected the loop which is collecting key
presses
knows when the number is complete. Like this....
Buffer var byte
Key var byte
Enter_Key var byte 'this is the value to look for
'as the enter key.
Buffer = 0
GetInp: 'was Main:
If Key = Enter_Key GOTO SetInp
Goto GetInp
SetInp:
'Now we have the desired value
'do whatever with it....
'Dont forget to check for new keypresses now and then..
From: Jared Hoylman [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=g4A0fciMNGkiTl1CN1YXclc7eI5CUd4mnL6rjEt89FbukOuSCI-rk0Pbcbio49ZhrqiNN-iFfLR5tfLBFc04]electrolinx@y...[/url
Sent: Thursday, June 22, 2000 9:09 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: KeyPad Data
Tobin,
Buffer var byte
Key var byte
Buffer = 0
Main:
Goto Main
key "1"
Buffer = 0 * 10 + 1
so
Buffer = 1
Buffer = 1 * 10 + 2
so
Buffer = 12
so
Buffer = 120
to 200.
Jared
> 0 and 200.
> Thanks anyway!!!
> Tobin
> get
> 85 and
> mualtiplied
> receives
> > Regards
> > Mohamed REfky
> > >From: ttm@g...
> decoder.
> Example
> > >Thanks!!!
> > >Tobin M.
> __
Do You Yahoo!?
http://im.yahoo.com
Thats that works great!!!
Tobin Moore
--- In basicstamps@egroups.com, "Witherspoon, Michael J"
<michael.j.witherspoon@i...> wrote:
> Last step is to have one key on the keypad desiginated as an enter
key
key
> presses
> Buffer var byte
> Key var byte
> 'as the enter key.
> Buffer = 0
> GetInp: 'was Main:
> Goto GetInp
> SetInp:
> From: Jared Hoylman [noparse][[/noparse]mailto:electrolinx@y...]
> Tobin,
> Buffer var byte
> Key var byte
> Buffer = 0
> Main:
> Goto Main
press the
> key "1"
> or
> Buffer = 0 * 10 + 1
> so
> Buffer = 1
> or
> Buffer = 1 * 10 + 2
> so
> Buffer = 12
> or
> so
> Buffer = 120
have
of zero
> to 200.
> Jared
> From: <ttm@g...>
between
> > 0 and 200.
> > Thanks anyway!!!
> > Tobin
you
> > get
valu
> > 85 and
> > mualtiplied
> > receives
> > > Regards
> > > Mohamed REfky
> > > >From: ttm@g...
> > decoder.
> > Example
one
to
> > > >Thanks!!!
> > > >Tobin M.
> > __
> Do You Yahoo!?
> http://im.yahoo.com
Take the first number 8 and multiply it by 10 then add it to 5 you get
85.When You press a third number for example 2,take the last valu 85 and
So you always take the key value and add it to the last value mualtiplied
by 10.First Number must not multiplies by 10 unless Basic Stamp receives
Regards
Mohamed REfky
>From: ttm@g...
>Thanks!!!
>Tobin M.
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
