onn\off push button
I would like to make a on\off button to switch on and off my whole
thing consisting of 1 bs2 and some other stuff. somehow I musst
program it, was thinking that the pushbutton could give the bs2 power
only when the button was held down and if the button is held down for
1-2 sec then the bs2 could make another output high which could turn
the whole thing on. do I have to use a relay? then the relay musst be
in working-mode when the thing is on. this uses a lot of current. any
other suggestions?
hc
other suggestions?
hc
column that described a circuit/program for this. Go to
ftp://ftp.nutsvolts.com/pub/nutsvolts/library/stampaps/ and get file
st_ap25.pdf .
