BS2 dead/alive? HELP!
Hay all you stampers,
After spending hours trying to find the problem and not I thought I'd get
some help, Im working on a small BS2 driven robot, afer I finished
building it I pluged in my pc and got the motors to work !yay! so I wrote a
program to move it around my desk (forward back left then right runnning in
a loop then the problem) downloaded the program to the stamp (note- Ive got
a little led hooked through a resister to the power supply lines) and the
power led start blinking as the motors turned so I new I needed a fresh
battery - unplugged the 9v and popped in a new one and nothing! the power
light turned on but the motors didnt even twitch!, fearing the worst I
popped out the stamp and put it in a spare board of education and hooked it
up to the pc, alt i does indentify that the stamp is there but when you
download a prog it say hardware failure.....help? Is the stamp ok but
the com system cooked? Thanx in advance!
-Alex
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
-Alex
Have you checked the current draw on those motors? You might be
overloading the stamps output capacity to sink 25ma. per pin, with a
total (sink) capacity of 50ma. per port. P0 - P8 equals one port, P9
- P15 equals the other port. If you are trying to source the current
through the output pins, the numbers are even lower, 20ma. per pin
and 40ma. per port.
I had a problem with an animate head kit where the requested power
supply was 9 volts at 1 amp. I used a 9 volt, 1 amp regulated
supply. With one or two of the four servos running, the head worked
fine, shortly after the third and fourth servos started the head
would stop moving. I found the supply regulated too well, at exactly
.99A it clamped down and pulled the supply voltage down enough to
cause the stamp to lockup. I ended up using a unregulated 9 volt,
1.5 amp supply and it worked fine.
Hope this helps.
Greg
thought I'd get
finished
wrote a
runnning in
Ive got
and the
fresh
power
worst I
hooked it
you
ok but
> -Alex
__
stamp with their large current draw. Are you powering your motors from a
separate source? If not, I would highly recommend, as a motor can run a
$3.00 9v batter dry very quickly. I killed my stamp when I was using
serarate power sources and go the common ground mix with power and put 15v
into the stamp. They replaced it for $30 (normally $20, but I got close to
$200 of free stuff because of the mistake). Just a few ideas. Try checking
if the regulator is still good. I.E. 5v coming out of the power pins.
-William
To: <basicstamps@egroups.com>
Sent: Monday, June 19, 2000 10:31 PM
Subject: [noparse][[/noparse]basicstamps] BS2 dead/alive? HELP!
a
in
got
it
> -Alex
carrier board it still wont accept a download, the editor says hardware
communications failed but alt i says hardward indentfied?
thanx
-Alex
>From: gjk@x...
>Reply-To: basicstamps@egroups.com
>Subject: [noparse][[/noparse]basicstamps] Re: BS2 dead/alive? HELP!
>Date: Tue, 20 Jun 2000 23:45:12 -0000
>Hi Alex
>and 40ma. per port.
>Hope this helps.
>Greg
>thought I'd get
>finished
>wrote a
>runnning in
>Ive got
>and the
>fresh
>power
>worst I
>hooked it
>you
>ok but
> > -Alex
>__
