troubles with a BSII and the L293D motor driver
Archiver
Hi group-
I'm at the end of my frustration tolerance with this problem. My BSII is on a
carrier board, powered by a single 9V battery. Here's the situation:
- I have the Vs(Supply) and Vss(logic supply)pins of the L293D connected to the
right side Vdd(+5) pin on the carrier board. One GND pin on the L293D is
connected to the carrier board Vss pin.
- Enable 1 is connected to pin 7 on the stamp.
- Input 1 is connected to ground, Input 2 to +5.
- Output 1 and 2 are connected to wires on a DC motor.
- A 33K resistor goes from enable to ground.
The first problem I had was that the enable pin had to be connected to ground to
stop the motor; without it, the pin would float, and the motor would run
continuously. An EE I know suggested I connect a high value resistor to ground,
and that seems to work. When I connect a wire from +5V to the Enable 1 pin, the
motor turns, when I remove it, it shuts off, so I know that when voltage is
applied, the motor SHOULD turn. To test that my program is actually putting out
a high voltage, I tested it with a 470ohm resistor connected to a LED, connected
to ground, and it worked properly. The problem I am asking you all about
happens when I run this program:
debug "wassup", bell, cr
dirs = 0
pause 2000
low 7
debug "turned 7 low", cr
pause 2000
debug "will it turn on?", cr
high 7
pause 2000
debug "off now"
dirs = 0
end
When run, first a bell chimes and the prog spits out "wassup" on the debug
screen. It pauses, writes "turned 7 low", pauses, then says, "will it turn
on"... and immediately resets. I hear the bell, and the same stuff I just
mentioned. This process continues indefinitely. All the while, the motor never
turns on at all.
If I remove the pin7 connection from the EN 1 pin and run the program, no reset
occurs. When run with a led, it turns on after "will it turn on?" and seems to
run normally.
I've even replaced the chip with another one and the same thing happens.
Surely someone in this group has had some experience and success with getting
the L293D motor driver chip to work. I'd really appreciate any help I can get.
Brandon Heller
northstarb@a...
dirs = 0
pause 2000
low 7
pause 2000
high 7
pause 2000
debug "off now"
dirs = 0
end
turns on at all.
run normally.
Brandon Heller
northstarb@a...
I think you have 2 problems with your setup:
1) Why do you set dirs=0? This sets all the Stamp pins to high impedance
inputs, which leaves the enable pin floating until the LOW command sets pin
7 to output. You could use dirs=$0080 to make the pin7 output and the
remaining pins inputs. But just using dirs=$FFFF will work, and makes all
pins outputs. You only need the statement once at the beginning of the
program.
2) Most motors cannot be run from a small 9V battery. The motor drain is
probably sucking down the supply voltage, which resets the Stamp. Connect
the L293 Vcc2 (pin 8) to an independent power supply. You can use "D"
batteries in series, or a 6 volt lantern battery if you don't have a power
supply. Don't forget to connect the external power supply negative to the
ground on the Stamp board.
Good luck,
Ray McArthur
is on a carrier board, powered by a single 9V battery. Here's the
situation:
to the right side Vdd(+5) pin on the carrier board. One GND pin on the
L293D is connected to the carrier board Vss pin.
ground to stop the motor; without it, the pin would float, and the motor
would run continuously. An EE I know suggested I connect a high value
resistor to ground, and that seems to work. When I connect a wire from +5V
to the Enable 1 pin, the motor turns, when I remove it, it shuts off, so I
know that when voltage is applied, the motor SHOULD turn. To test that my
program is actually putting out a high voltage, I tested it with a 470ohm
resistor connected to a LED, connected to ground, and it worked properly.
The problem I am asking you all about happens when I run this program:
> dirs = 0
> pause 2000
> low 7
> pause 2000
> high 7
> pause 2000
> debug "off now"
> dirs = 0
> end
never turns on at all.
reset occurs. When run with a led, it turns on after "will it turn on?" and
seems to run normally.
getting the L293D motor driver chip to work. I'd really appreciate any help
I can get.
> Thanks,
> Brandon Heller
> northstarb@a...
Use separate power supplies for the motor and the BSII. Couple the
motor drive commands via a proper isolation like open collector
transistor drive or opto isolators.
Never power a motor from the same supply as the BSII derives power.
The initial current load will drop out the BSII and reset it. The 9
volt does not have the current capacity to drive a motor, period.
Separate them and you should have better results.
Remember you just found out what did not work. So try something
different. If you have a scope you will be able to watch for the
effects on the power supply.
Ron
To: <basicstamps@egroups.com>
Sent: Sunday, June 18, 2000 9:52 PM
Subject: [noparse][[/noparse]basicstamps] troubles with a BSII and the L293D motor driver
> Hi group-
BSII is on a carrier board, powered by a single 9V battery. Here's
the situation:
connected to the right side Vdd(+5) pin on the carrier board. One GND
pin on the L293D is connected to the carrier board Vss pin.
to ground to stop the motor; without it, the pin would float, and the
motor would run continuously. An EE I know suggested I connect a high
value resistor to ground, and that seems to work. When I connect a
wire from +5V to the Enable 1 pin, the motor turns, when I remove it,
it shuts off, so I know that when voltage is applied, the motor SHOULD
turn. To test that my program is actually putting out a high voltage,
I tested it with a 470ohm resistor connected to a LED, connected to
> dirs = 0
> pause 2000
> low 7
> pause 2000
> high 7
> pause 2000
> debug "off now"
> dirs = 0
> end
debug screen. It pauses, writes "turned 7 low", pauses, then says,
"will it turn on"... and immediately resets. I hear the bell, and the
same stuff I just mentioned. This process continues indefinitely.
All the while, the motor never turns on at all.
program, no reset occurs. When run with a led, it turns on after
"will it turn on?" and seems to run normally.
happens.
with getting the L293D motor driver chip to work. I'd really
> Thanks,
> Brandon Heller
> northstarb@a...
<snip>
I haven't closely inspected your code, but it would seem that your
most pressing problem is that the BS2 is resetting. This is usually
because you are drawing too much current and the Stamp's on-
board brown-out detector is resetting.
For starters, be sure you have nothing connected to the Stamp's
regulator (Pin 21) -you should certainly not try to power the L293 or
any motors with this supply. What is happenign is that when the
motor goes to turn on, it draws so much current that the voltage
briefly dips below the threshold of the Stamp's brown-out detector
and the circuit resets and the motor shuts-off. If you can supply
enough current, the voltage will not dip.
Check the power supply that you're using. Is it rated for sufficient
current for your project ? Have you got a decently-sized electrolytic
cap on the output (say, 1000 uF, 15V) ? If you do, then you
shouldn't be having any troubles.
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: +403-730-8603 Fax: +403-730-8903
http://www.hvwtech.com
