motor mind B
I am trying to implement the motor mind b on a traveling gantry. I
want to use a rotating disk with a hall effect sensor to determine
the position of the gantry. I have loaded the demonistration code
from solutions cubed manual but when I put a meter on the motor
output I don't get any current. Also how fast can the BS2 receive
input in the count mode of the motor mind?
Thank-you
Mark Gillett
Thank-you
Mark Gillett
my motor in reverse direction, using the motor mind b. In the subroutine
labeled "back" (listed below) I have to get the motor going forward at the
duty cycle I want and then send the reverse command. In this program, the
forward and halt subs work well but the back subcommand flips constantly
between forward and reverse. I feel quite certain that I will be embarrassed
when someone tells me how simple my problem is, nevertheless I will
appreciate any help this group can give me.
(P.S.) as per Dwayne Reid's advice I have turned off the html formatting of
my emails. Sorry for the inconvenience. Please let me know if my emails
continue to generate needless gibberish in the header.
output 8
input 6
tm con 8
fm con 6
high fm
x var word
y var word
low fm
pause 20
high fm
pause 25
start:
high 4 'set pin state for rctime
function
high 2 'set pinstate for rctime
function
pause 1
rctime 4,1,x 'check forward position of
joystick
rctime 2,1,y 'check rear position of
joystick
debug ? x 'show me what x is doing
if x=0 and y=0 then halt 'if joystick is neutral motor is
stopped
if not x=0 and y=0 then forward 'if x has value and y doesn't then
motor fwd.
if not y=0 and x=0 then back 'if y has value and x doesn't then
motor back.
Forward:
serout fm,396,[noparse][[/noparse]$55,$03,$DD] 'motor mind B forward 86%
goto start
back:
serout fm,396,[noparse][[/noparse]$55,$03,$DD] 'motor mind b forward 86%
serout fm,396,[noparse][[/noparse]$55,$01]
'Reverse command for motor mind b
goto start '***** this
is a question--Why doesn't theMMb
'have
a command for starting a motor in reverse?
halt:
serout fm,396,[noparse][[/noparse]$55,$00] 'stop command for Motor
mind b
goto start
I was wondering if u can hook up the motor mind B up to the basic stamp?? And
how u do it..
Justin
serial connection and is very easy.
-- Jon Williams
-- Parallax
From: Digitalcowboy00 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G27FHfEcSDSh_QZiskDuj63rYIz-LKz7OAc5-f2CQKcICVoYR_dkxU1DR4MRKwyc4jOxQs4NDyf60n2NMBDXYJHbhQ]DigitalCowboy00@s...[/url
Sent: Monday, August 04, 2003 2:35 PM
Subject: [noparse][[/noparse]basicstamps] Motor mind B
Dear group,
stamp?? And how u do it..
Justin
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
samples for a Stamp.
http://www.solutions-cubed.com/Products/MotorMindB/motormindB_download.htm
There is also some info in one of the Nuts & Volts articles from a few
years back.
And how u do it..
stamp, but the code they have is more then i need. Does any one now a
simple code to do this?
justin
Sent: Monday, August 04, 2003 2:55 PM
Subject: RE: [noparse][[/noparse]basicstamps] Motor mind B
> Yes. There are BASIC Stamp examples in the documentation. It uses a
> -- Jon Williams
> -- Parallax
> From: Digitalcowboy00 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hYecnGU0YnY4fcPIvL8-H7a0GMnF8WwdJkiA_bq1FcNnArz6AHszea4iJmy_ufPb9n_ztELNRG-Dd4K8SuST6vA]DigitalCowboy00@s...[/url
> Dear group,
> Justin
> abuse@p....
I am a student of Mechanical Engineering at University of South
Florida.I have a limited background of electronics and through a
friend of mine working on BAsic Stamps, I learnt about this group.
I am working in the field of Robotics and am making a robot arm
gripper. I need to control three DC gearmotors and ensure the work in
a synchronised fashion using a Motor Mind B. I had a few questions as
to how to do it.
1. Is it possible to control three DC Motors using a single Motor
Mind?
2.The operating voltage for each motor is 0.29 A and a peak voltage
is about 0.65 A. Is this voltage too high for the Motor Mind B?
3. How do I connect the leads of three motors to the Motor Mind B and
how do I connect it to the Basic Stamp?
I tried running one motor using a sample program as provided in the
S3 manual. It worked fine. Now I am trying to run a single motor in a
reversible manner using a centre-off toggle switch. What values do I
specify in the program? I mean do I specify a -1,0,1 values for
Reverse-Stop-Forward or do I need a 1,0,2 Values for the same?
I understand that this being my first email and am asking too many
questions. And its quite likely I may be too vague and unspecific
about my queries If someone can provide me some help, I can finish my
projects really quickly.
Koushik
