Reading a pressure transducer signal with a bs2 stamp.
Archiver
·i have a pressure transducer that gives an output between 1volt and 4volts that is proportional to a varying pressure applied to the transducer.
·does anyone know how this varying voltage (and pressure) may be read by the bs2?
·the way varying·resistance can be read using the rctime feature, is the type of thing that would be ideal.
· i would appreciate any assistance.
wrote:
> I HAVE A PRESSURE TRANSDUCER THAT GIVES AN OUTPUT BETWEEN 1VOLT
AND
4VOLTS THAT IS PROPORTIONAL TO A VARYING PRESSURE APPLIED TO THE
TRANSDUCER.
> DOES ANYONE KNOW HOW THIS VARYING VOLTAGE (AND PRESSURE) MAY BE
READ BY THE BS2?
> THE WAY VARYING RESISTANCE CAN BE READ USING THE RCTIME FEATURE,
IS
THE TYPE OF THING THAT WOULD BE IDEAL.
> I WOULD APPRECIATE ANY ASSISTANCE.
I think you are going to need to use an ADC.
See http://geocities.com/SiliconValley/Orchard/6633/altimeter.html
for a good discussion of reading a pressure transducer with a BS2
site, it gives hookup and programming instructions for an ltc device (12
bits)
Norm & Monda
Cozy MK IV #202
Ford V-6 Powered
To: <Basicstamps@egroups.com>
Sent: Tuesday, June 13, 2000 2:36 PM
Subject: [noparse][[/noparse]basicstamps] READING A PRESSURE TRANSDUCER SIGNAL WITH A BS2
STAMP.
I HAVE A PRESSURE TRANSDUCER THAT GIVES AN OUTPUT BETWEEN 1VOLT AND 4VOLTS
THAT IS PROPORTIONAL TO A VARYING PRESSURE APPLIED TO THE TRANSDUCER.
DOES ANYONE KNOW HOW THIS VARYING VOLTAGE (AND PRESSURE) MAY BE READ BY
THE BS2?
THE WAY VARYING RESISTANCE CAN BE READ USING THE RCTIME FEATURE, IS THE
servo cylinders of an automatic transmission relative to transmission output
speed.
I am intending to store the two values consecutively in the stamps EEPROM
and then read them after the end of the vehicle test run.
To: <basicstamps@egroups.com>
Sent: Wednesday, June 14, 2000 1:42 PM
Subject: Re: [noparse][[/noparse]basicstamps] READING A PRESSURE TRANSDUCER SIGNAL WITH A BS2
STAMP.
> hello,
> LTC2400 A/D from Linear Technology is for weigh-scale and pressure
> measurement applications.Look at data sheet page 30,there is a code for
> BS2.
> What would you like to measure?.I'm also interested in such applications
> specifically weighing systems ))
> Regards
> Mohamed RefkY
> >From: "Keith Moore" <keithmoore1@n...>
> >Reply-To: basicstamps@egroups.com
> >STAMP.
> >Date: Tue, 13 Jun 2000 14:36:41 -0400
> >TRANSDUCER.
> >THE BS2?
> ________________________________________________________________________
> Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
NetZero - Defenders of the Free World
Click here for FREE Internet Access and Email
http://www.netzero.net/download/index.html
BS2.
What would you like to measure?.I'm also interested in such applications ((
Regards
Mohamed RefkY
>STAMP.
>TRANSDUCER.
>THE BS2?
What pressure transducer are you using?
Paul Verhage
p.s.i. and outputs up tp 5V, I am working up to a lower pressure.
Sent: Wednesday, June 14, 2000 7:06 PM
Subject: RE: [noparse][[/noparse]basicstamps] READING A PRESSURE TRANSDUCER SIGNAL WITH A BS2
STAMP.
> Paul Verhage
Sent: 15 June, 2000 5:56 AM
STAMP.
> Transducer is an Omega PX181-500G5V. Although it handles pressures up to
500
I've not heard of that one before. I'm looking for a pressure transducer
that will give an output for 1 atmosphere to vacuum. Can you tell me where
you got this sensor from? I'll like to look into it.
Paul
nature, you may want to look at a pressure/vacuum transducer that is
installed on a turbocharged Buick Grand National. It uses a 5 volt
reference value, but I can't recall the upper pressure limit.
David
transducer
me where
> Paul
at DIGI-KEY . Reference voltage of 5 volts output between0.25 and
4.5v at 15psi.
>From: "david " <david@r...>
>Subject: [noparse][[/noparse]basicstamps] Re: READING A PRESSURE TRANSDUCER SIGNAL WITH A BS2
>STAMP.
>Date: Sun, 18 Jun 2000 13:16:07 -0000
>Paul, depending on your application and if it is auotmotive in
>David
>transducer
>me where
> > Paul
for 1ams to vacuum you need a psia transducer.
pounds per square inch absolute.
Norm & Monda
Cozy MK IV #202
Ford V-6 Powered
Sent: Friday, June 16, 2000 6:42 PM
STAMP.
> From: Keith Moore <keithmoore1@n...>
> STAMP.
> 500
where
> Paul
www.omega.com
Their PX141-015V5V transducer handles from -15 to 0 PSIV.
STAMP.
> STAMP.
> 500
where
> Paul
>use the mpx series from newark.
Prof. Anderson has these for less and doesn't require a minimum order. Check:
http://www.phanderson.com/
and click 'ordering information'.
Duncan
