Stamps and AC Noise Reset, Non-Issue
Thanks Chris,
Thanks for the reply and the testimonial.
I too, have had zero problems with "noise generating a reset" type of
problem.
If this is happening to someone they probably have a power supply
problem.
Ron
To: <basicstamps@egroups.com>
Sent: Monday, June 12, 2000 1:45 PM
Subject: Re: [noparse][[/noparse]basicstamps] Basic Stamp PLC Style Application Board
> I have a bs2sx mounted 25mm (1 inch) away from a 40Amp solid state
relay
> switching a 240 volt ac motor with zero problems ever, outside noise
> should'nt be a problem with the reset. Also am very interested in
the PLC
> replacement option.
> From: Valles, Alfredo <AValles2@v...>
> Sent: Monday, June 12, 2000 9:32 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Basic Stamp PLC Style Application Board
> > What about the noise generated on the AC line due another
machinary
> > near the Stamp. It doesn't affect? How can we avoid the stamp
reset due
> this
> > problem?
> > Alfredo Valles
problem.
problem.
Ron
relay
the PLC
> replacement option.
machinary
reset due
> this
> > problem?
> > Alfredo Valles
due to proximity to AC loads being switched it's associated with the
use of mechanical relays. Since they can switch anywhere in the AC
waveform, and their contacts bounce for several milliseconds, they
can be quite potent little wide-spectrum RF noise generators. Solid-
state relays that switch on the zero-crossing of the AC waveform
don't have this problem.
Want to play Mr. Science? Set an AM radio between stations and
position it next to the relay box. Run the relays through their
paces. The noise is amazing. Repeat the experiment with zero-cross-
switching solid-state relays.
----Original quotes:
of
> problem.
> problem.
...and
> relay
noise
...and
> machinary
> reset due
> > this
> > > problem?
> > > Alfredo Valles
world they are far more common than the more expensive solid state relays.
Also mechanical relays are used because you can have more than one set of
contacts packaged into one relay with a common coil. This is not so easy
with solid state relays. One other matter to consider are motors and their
starters. It is almost non-existant to see a solid state starter for a 60 hp
motor or even for a 10 hp motor. Since the vast majority of motors in
industry are three phase the solid state starters are practically priced out
of existence.
In the real world of industrial machinery noise re-setting ANY type of
microprocessor controlled device is a very big headache. And the only real
solution is proper wiring using twisted pair shielded wiring for the inputs
and proper ground and power planes on the PC cards as well as proper
filtering and isolation of the inputs.
Randy A.
stamps@s... writes:
> Almost invariably when you hear about problems with Stamps resetting
I've had a few -- just a few -- problems using a Stamp in an industrial
application where a VFD (variable frequency drive) was being used. We've
solved most of the problems by rerouting the wiring to the Stamp and by using
ferrite torroids on the Stamp power supply and other inputs.
