GPS to Stamp
> Thanks for your response. Can I pick your brain I step further. I
> have
> the code for the Stamp II that can decipher GPRMC data line from a gps
> receiver with a standard serial output. My problem is when I hook my
> ser out of my "jupiter" gps to read or see the data, via my laptop,
> 9600, 8,N,1 or any other logical combination, I get garbage. I tried
> changing all possible combos of inputs that I know to the GPS, i.e.
> reset, nema ver rockwell ser data, etc. Any Ideas Thanks Ralph
It probably has TTL level inverted data i/o and needs an RS232 level
interface(MAX232, etc) to connect to a PC.
> have
> have
Save yourself lots of grief. Here are the locations of all the documentation
that you will ever need for your Jupiter. I suspect that the Jupiter powers
up in the default binary data mode and the garbage you see really isn't
garbage:
Zodiac GPS Receiver Family Designers Guide - (142 page)
http://www.unitronic.de/rockwell/pdf/gps/Zodiac%20DG_GPS-33.pdf
Zodiac Serial Data Interface Specification - (84 page)
http://www.c2-tech.com/~steveb/ka9mva/zodiac.pdf
Manual - (18 page)
http://www.unitronic.de/rockwell/pdf/gps/gd003g.pdf
Hope this helps
Vic
_____________________________________________________
Victor Fraenckel - The Windman vfraenc1@n...
Home of the WindReader Electronic Theodolite
Read the WIND
richard
To: "Stamp Mailing List" <basicstamps@egroups.com>
Sent: Sunday, June 11, 2000 4:55 AM
Subject: [noparse][[/noparse]basicstamps] Re: GPS to Stamp
> > have
documentation
powers
> garbage:
> Manual - (18 page)
> Hope this helps
> Vic
> Read the WIND
>> have
Try 4800,8,N,1...
BTW what type of program are you using to read in the data, and where did
you purchase an antenna??
_______________________________________________________
| Pay attention to the details |
| for it is the little details that |
| will conquer you |
|_______________________________________________________|
Joseph Conner
Wentz Hall
Oklahoma State University
Graduate Student
(405)744-1887
the serial input of my laptop and run HyperTerminal, I can see the data ok.
When I hookup the output of the Jupiter receiver to the same input on my
laptop, It looks like garbage. I tried every baud rate, stop bits, parity,
etc. I don't have an antenna hooked up yet. I do have an antenna but I'm
waiting for an adapter.
Ralph
To: <basicstamps@egroups.com>
Sent: Wednesday, June 21, 2000 3:11 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: GPS to Stamp
> >> have
> Try 4800,8,N,1...
> | will conquer you |
> Joseph Conner
> Wentz Hall
> Graduate Student
> (405)744-1887
make sure that you set the baud to 4800
select NEMA 103
prob want to hook up 3 volt memory battery
need to convert to real RS232 level signals - the gps outs out ttl rather
than +/- 10 volts or what ever RS232 is
you need a converter chip like a Max-232
I am trying to parse the huge amount of data that the gps dumps onto the
chip
richard
Sent: Wednesday, June 21, 2000 2:00 PM
> When I take the output of my hand held GPS receiver and connect it to
ok.
parity,
> Thanks
> Ralph
> From: Joseph Conner <connjos@w...>
> > >> have
gps
> > Try 4800,8,N,1...
did
> > | will conquer you |
> > Joseph Conner
> > Wentz Hall
> > Graduate Student
> > (405)744-1887
Where did you get the antenna adapter!?! I have four of these Jupiter
boards ready to test with, but I haven't ordered antennas yet. Have you
determined the exact connector required?
The spec sheet for a -221 says that it offers a straight OSX ( female? ) on the
board. Can't find many of the small active antennas that offer an osx
connector or adapter. I read somewhere that OSX is also called MCX but that
didn't help things much. Ideally, I'd like a right angle adapter and then be
able to connect the antenna to that. I need to stay with the smaller family of
connectors for a small footprint application; the usual bnc is way too big for
my app. There aren't many 'quick order' sources for a solution or reference.
Care to share your info? (g) In exchange I can offer the name of a vendor that
sells a plug-compatable replacement for this board. The prices are decent
too! This vendor has antennas at quite favorable prices ~$25.00 in low qtys.
I have not determined if this is an active ( probably not ) or passive. Great
price if it is an active antenna.
Bill Mrozinski - DCS
> Thanks
> Ralph
> > >> have
> > Try 4800,8,N,1...
> > | will conquer you |
> > Joseph Conner
> > Wentz Hall
> > Graduate Student
> > (405)744-1887
From my research your going to need to add a MAX232 to the TTL level serial
pins provided by the Jupiter. There are some serial ports that are forgiving
enough to tolerate the 5v swing, but laptops are notorious for not being among
them. Additionally, the 0v low logic level is even more troublesome as the
true RS232 spec calls for a +12v/-12v swing. The MAX232 is an quick and easy
solution and will remove all doubt concerning serial data line flakiness.
Hope this helps,
Bill Mrozinski
> Thanks
> Ralph
> > >> have
> > Try 4800,8,N,1...
> > | will conquer you |
> > Joseph Conner
> > Wentz Hall
> > Graduate Student
> > (405)744-1887
works fine outside
but no reception in the house
seems to make no difference as to straight wire or curled up for circular
polarization
richard
Sent: Wednesday, June 21, 2000 3:33 PM
> Ralph,
on the
that
be
family of
for
reference.
that
qtys.
Great
> Thanks,
to
ok.
parity,
I'm
> > Thanks
> > Ralph
I
> > > >> have
gps
my
tried
> > > Try 4800,8,N,1...
did
> > > | will conquer you |
> > > Joseph Conner
> > > Wentz Hall
> > > Graduate Student
> > > (405)744-1887
When I was reading back researching for the prev post I saw a post from you
( I think? ) saying that they had used an 8" length of wire successfully. I'm
willing to try it as long as it shouldn't harm the unit. My analog ele is weak,
does this provide a sufficient load to avoid any damage to the receiver or is
this even an issue? What about the antenna ground lead in this case, just
hanging open or what? This sounds like a great temp solution until I can line
up a right angle osx/mcx/sma(b?) connector and appropriate mate for an antenna.
I have been delaying my project ( and powering up any of these boards! ) until I
had an antenna to connect up.
All the 'shrink-wrap' antennas have a huge lead on them as well, I'd like
one about 3" long and several others about 10" long only. I think I'm gonna
have to roll my own! ( If I can source the connectors that is...) Thanks for
the tip though and I would welcome any additional insight you may have on the
above issues...
Bill
dakota wrote:
> I soldered a 4 inch piece of wire onto the center of the antenna connector -
> works fine outside
> polarization
> richard
> From: William E. Mrozinski <dcs@h...>
> > Ralph,
> on the
> that
> be
> family of
> for
> reference.
> that
> qtys.
> Great
> > Thanks,
> to
> ok.
> parity,
> I'm
> > > Thanks
> > > Ralph
> I
> > > > >> have
> gps
> my
> tried
> > > > Try 4800,8,N,1...
> did
> > > > | will conquer you |
> > > > Joseph Conner
> > > > Wentz Hall
> > > > Graduate Student
> > > > (405)744-1887
>etc.
Save yourself lots of grief! Here are the locations of all the documentation
garbage. You will need to command the Jupiter into the NMEA mode as it's
native mode of communication is Binary. Please take the time to read ALL the
documentation:
Manual - (18 page)
Hope this helps
Vic
Read the WIND
of commectors as well as adapters and cacles.
>>> "William E. Mrozinski" <dcs@h...> 06/21/00 06:47PM >>>
Richard,
above issues...
Bill
> works fine outside
> polarization
> richard
> > Ralph,
> on the
> that
> be
> family of
> for
> reference.
> that
> qtys.
> Great
> > Thanks,
> to
> ok.
> parity,
> I'm
> > > Thanks
> > > Ralph
> I
> > > > >> have
> gps
> my
> tried
> > > > Try 4800,8,N,1...
> did
> > > > | will conquer you |
> > > > Joseph Conner
> > > > Wentz Hall
> > > > Graduate Student
> > > > (405)744-1887
rx - it just wont work as well as it could. That however is definitely not
the case for transmitters and transmitting antennas.
Also the gps is in the 1500 MHz range - that is the reason I choose a 4 or 8
inch wire since it is a multiple of the wavelength.
The transmission line losses are huge at that frequency. so make the lead in
wire as short as possible- I had a zero length transmission line when I
soldered my antenna to the center terminal.
an active antenna is a good solution to the problem but I am on a shoestring
budget and I didn't want to spend $30 -100
I know that ground planes are good for vertical polarized antennas, I guess
I am relying on the ground traces on the board for the ground plane - it
works anyway
Also I believe that the gps signal is right hand circularly polarized - I am
not sure that a ground plane helps in that situation.
richard
Sent: Thursday, June 22, 2000 8:13 AM
> If you Know what type connector it is try www.pasternack.com they have all
kinds of commectors as well as adapters and cacles.
> Richard,
from you
I'm
weak,
is
line
antenna.
until I
like
gonna
for
the
> above issues...
> Bill
connector -
> > works fine outside
circular
> > polarization
> > richard
> > > Ralph,
Jupiter
you
( female? )
> > on the
but
> > that
then
> > be
> > family of
big
> > for
> > reference.
vendor
> > that
decent
low
> > qtys.
passive.
> > Great
> > > Thanks,
it
> > to
data
> > ok.
on my
> > parity,
but
> > I'm
> > > > Thanks
> > > > Ralph
further.
> > I
> > > > > >> have
from a
> > gps
hook
> > my
laptop,
> > tried
> > > > > Try 4800,8,N,1...
where
> > did
> > > > > | will conquer you |
> > > > > Joseph Conner
> > > > > Wentz Hall
> > > > > Graduate Student
> > > > > (405)744-1887
Actually is was sent to me from someone else. A piece of wire would
probably work on a passive antenna but not an active one, (which needs a dc
voltage to drive the preamp in the antenna).
Ralph
Sent: Thursday, June 22, 2000 9:13 AM
> Richard,
from you
I'm
weak,
is
line
antenna.
until I
like
gonna
for
the
> above issues...
> Bill
connector -
> > works fine outside
circular
> > polarization
> > richard
> > > Ralph,
Jupiter
you
( female? )
> > on the
but
> > that
then
> > be
> > family of
big
> > for
> > reference.
vendor
> > that
decent
low
> > qtys.
passive.
> > Great
> > > Thanks,
it
> > to
data
> > ok.
on my
> > parity,
but
> > I'm
> > > > Thanks
> > > > Ralph
further.
> > I
> > > > > >> have
from a
> > gps
hook
> > my
laptop,
> > tried
> > > > > Try 4800,8,N,1...
where
> > did
> > > > > | will conquer you |
> > > > > Joseph Conner
> > > > > Wentz Hall
> > > > > Graduate Student
> > > > > (405)744-1887
Thanks for the response. I drove the NEMA Protocol input pin 7 to a low per
the documentation and I still can't interpret the data.
Ralph
To: Stamp Mailing List <basicstamps@egroups.com >
Sent: Thursday, June 22, 2000 6:05 AM
parity,
> >etc.
documentation
powers
the
> documentation:
> Manual - (18 page)
> Hope this helps
> Vic
> Read the WIND
Thanks for the response. So the output of the Jupiter is TTL? Let me know
if you need help deciphering the GPS data. I have the code that deciphers
GPRMC data line. Easily changed for your app.
Ralph
Sent: Wednesday, June 21, 2000 4:03 PM
> been there done that
> select NEMA 103
> chip
> richard
> From: Ralph Rogers <fdcsouth@9...>
to
> ok.
> parity,
I'm
> > Thanks
> > Ralph
I
> > > >> have
> gps
my
tried
> > > Try 4800,8,N,1...
> did
> > > | will conquer you |
> > > Joseph Conner
> > > Wentz Hall
> > > Graduate Student
> > > (405)744-1887
There is a company in Jupiter/Stuart Florida that sells the adapter but
the adapter I want is for a Motorola active antenna I got free, (pre amp
included). I did a search for OSX on web crawler and yahoo to find a
company. You can also buy connectors and crimpers for them. I don't care
to go that direction. By the way, what is DCS.
Ralph
Sent: Wednesday, June 21, 2000 4:33 PM
> Ralph,
on the
that
be
family of
for
reference.
that
qtys.
Great
> Thanks,
to
ok.
parity,
I'm
> > Thanks
> > Ralph
I
> > > >> have
gps
my
tried
> > > Try 4800,8,N,1...
did
> > > | will conquer you |
> > > Joseph Conner
> > > Wentz Hall
> > > Graduate Student
> > > (405)744-1887
ill take you up on that
please send me ASCII version
since I am working on basicx-24
thanks
richard
Sent: Thursday, June 22, 2000 7:26 PM
> Richard
> Ralph
> From: Dakota <rfriedrich@i...>
> > select NEMA 103
rather
> > chip
> > richard
> to
data
> > ok.
my
> > parity,
> I'm
> > > Thanks
> > > Ralph
further.
> I
> > > > >> have
a
> > gps
hook
> my
laptop,
> tried
> > > > Try 4800,8,N,1...
where
> > did
> > > > | will conquer you |
> > > > Joseph Conner
> > > > Wentz Hall
> > > > Graduate Student
> > > > (405)744-1887
>Ralph,
on the
family of
for
that
Great
Have you found out where you can get the adapter for the Jupiter GPS yet..
I am working with one as well, and have yet to find a source for the antenna..
BTW... have you found any place that carries the adaptor for the pins. I
relly do not want to just solder the wires in place. Any infor you can give
would be of great aid, as I am planing on using this unit in a project for
school.
richard
Sent: Monday, July 24, 2000 9:17 PM
> At 16:33 6/21/2000 -0400, you wrote:
> >Ralph,
Jupiter
> on the
that
then be
> family of
big
> for
reference.
vendor
> that
decent
qtys.
> Great
antenna..
give
> school.
and I have a few questions.
1. Has any gotten the Jupiter to work in RMC mode yet, and if so how did
you get it in the right mode?
2. Did you find that you where able to directly hook the STAMP to the
Jupiter with the serial port?
3. Where you able to get LABMON working?
Any information or schemactics on how you have gotten the system to work
would be of great aid...
Thnks in Advance..
Joe
what is rmc mode ?
thanks
richard
Sent: Friday, September 01, 2000 12:38 AM
> I am working on a project the involes the 'Jupiter' GPS and the STAMP II
> Thnks in Advance..
> Joe
