RCTime question...
Hi all! I am using RCtime to scan 9 I/O lines (each attached to a CdS
cell/capacitor combo). I understand the I/O lines to be grouped in two buses
of 8 I/O lines each, so 1 of the lines that I will be using will be on the
second bus. OK, enough of that... The time in which the Stamp can cycle
through all 9 lines is a major issue, so... (My Question)... Will the one
line being on a separate bus cause an extra delay in the execution time? If
so, by how much? Also, in addition to the charge/discharge time of the
capacitor, how long does it take to execute a single RCtime command? How long
in-between RCtime commands?
Thanks in advance,
Edward Kindler
Thanks in advance,
Edward Kindler
buses
If
long
It takes 220 microseconds in between each RCtime command. Plus the time
for the command itself, in 2 microsecond units. To make the execution as
fast as possible, make the capacitor as smallas possible consistent with
the resolution you need for your application. The 9 lines all work the
same for RCtime--it doesn't matter which pins you use.
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
