Questions about keypad
> 3- I need information about EDE 1144 IC keypad encoder from Jameco.
This is made by E-Labs You can check out the details on it at
http://www.elabinc.com/
Tim
[noparse][[/noparse]Denver, CO]
Tim
encoder required, just a cheap keypad, plus some of the code is included.
regards, Chris
To: <basicstamps@egroups.com>
Sent: Thursday, June 08, 2000 4:51 AM
Subject: [noparse][[/noparse]basicstamps] Questions about keypad
> Hello group,
> I have some questions about keypad:
> 1- Keypad gives the value of the key that has been pressed.
> How can I do the following with BS2:
> pressing key '2', the display is '2'and when pressing key '3',the
> display is '23'.. and so on ?
> 2- Where can I get inexpensive keypad kit.
> Thank you in advance
> Mohamed refky
> ________________________________________________________________________
> Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
If you want to get the number 23 from two seperate keypresses
you can setup a couple byte variables to hold each key value
received, and
1. Multiply the first digit received by 10
2. Grab the second key value and simply add it to the first.
IE,, the first digit received is 2, and you store it in B0, then B0 = B0 X
10.
you now have 20. The second digit arrives and you add it to B0. You
now have the number 23........ after two key presses.
http://www.rentron.com/Ser-Key.htm This is a 10-key serial key encoder PIC
that takes key entry from simple push-button switches. You won't need to
buy an expensive keypad, just use any el-cheapo normally-open push-button
switches to build your own 10-key serial keypads.
It was specifically designed for the Basic Stamp, and the
baud rate can be changed on-the-fly from N2400 to N9600.
Bruce
> Mohamed refky
Mohamed refky
Refer to losa number 157,ther is :
E-mail author for source code.
Thank You
Mohamed Refky
>From: "Chris Anderson" <fes@g...>
>Reply-To: basicstamps@egroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] Questions about keypad
>Date: Thu, 8 Jun 2000 07:39:00 +0800
>refer losa Number 157 in the basic stamp list of stamp applications, no
> regards, Chris
>From: Mohamed REFKY <refky@h...>
> > Hello group,
> > Mohamed refky
digits,but the user may press 2 then 3 (23) or 234 or 2345,three different
power for 2&3 and two for 4 ....?
>From: "Bruce" <breyno2@r...>
>Date: Wed, 7 Jun 2000 18:31:08 -0600
> > Hello group,
>received, and
>10.
>Bruce
> > Mohamed refky
