Graphical LCD Display
What do I need to control a small (32x120) graphical LCD display off
the stamp? Can anyone recomend a good controler chip and show me how
to interface it with the STAMP?
-Chris
-Chris
in business (www.seetron.com). Lots of clones out there too.
If you want to drive a 4 or 8 bit interface, you can find Stamp I code in
the Parallax app notes. You can also find a library in my book
Microcontroller Projects with Basic Stamps which drives the LCD directly
from a Stamp II. www.al-williams.com/awce/sbook.htm
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller.
http://www.al-williams.com/awce/pak1.htm
> From: Chris Rosney [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IZ2rrXHirwjrDy07vqFaAbrkJbBWeTStbjV2XqKCnXp7LjEe6rrn7wt2SsaeCSCEc12b07wVhvvWbRN0HA]c_rosney@y...[/url
> Sent: Friday, June 02, 2000 6:02 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Graphical LCD Display
> -Chris
c_rosney@y... writes:
Save yourself a lot of work (=$) and go to www.seetron.com. Scott Edwards
has a serial-controlled graphic LCD called the G12032 that is very easy to
connect to the Stamp.
off
how
> -Chris
The G12032 serial LCD module (part number SGX-120L) is Stamp
compatible and supported by several BS2 application notes. It's also
on sale for 20% off at the Seetron online store through June 9, 2000--
see www.seetron.com for details.
App notes: www.seetron.com/lcd_andex.htm
Specs on display: www.seetron.com/sgx120_1.htm
