Analog Multiplexer / Switch
Hi All,
Looking for a way to measure current in an automobile application. First
thoughts were to insert a shunt into the circuit with a very low, but known
resistance and measure the drop across the shunt. Assuming a drop in the
50-100mV range, what would be a good way to meausre that? I'd also like to
be able to measure the same at about 10-12 points. Could some sort of
analog switch be used to select a voltage source? My thoughts were to use
an analog switch (isn't the 4066 along these lines?) that could be used to
select the voltage source to be measured, but then I recall that some A/D
chips also support multiple channels. Would it be better to have multiple 4
channel A/D devices rather than a single A/D device with a 12 way switch?
All input greatly appreciated.
-- Mitch
-- Mitch
I would question the accuracy of inserting an analog switch between the
source and measuring device; all solid state switches have some insertion
loss and possible offsets. This is especially true when measuring levels in
the millivolt range. The multichannel A/Ds would probably be better, unless
you can use mechanical switches.
My 2 cents,
Ray McArthur
> Hi All,
known
to
4
To: <basicstamps@egroups.com>
Sent: Friday, June 02, 2000 2:56 PM
Subject: Re: [noparse][[/noparse]basicstamps] Analog Multiplexer / Switch
> Mitch:
in
unless
> My 2 cents,
> Ray McArthur
> > Hi All,
First
> known
the
> to
use
to
A/D
multiple
> 4
switch?
