BASIC Stamp II & PS/2 mouse - more
Hi all,
Thinking some more on this project, there is no reason why I couldn't use a
serial mouse into the Stamp and generate the PS/2 codes to the PC.
Jean-Michel.
Jean-Michel.
> Hi all,
couldn't use a
> Regards,
> Jean-Michel.
How is your project progessing ? I'm also very interrested, because i
would like to emulate a ps/2 mouse with a basic stamp, I already
destroied about a dozen of ps/2 mouses trying to....
Best Regards,
Hennie Vos
The Netherlands
I've seen something about mouse and Stamp in the LOSA (List Of Stamp
Application).
I don't know the link, but it is one on Parallax'site.
Hope this helps...
Phil.
To: <basicstamps@egroups.com>
Sent: Saturday, July 29, 2000 8:47 AM
Subject: [noparse][[/noparse]basicstamps] Re: BASIC Stamp II & PS/2 mouse - more
> --- In basicstamps@egroups.com, Jean-Michel Howland <vege@v...> wrote:
> > Hi all,
> couldn't use a
> > Regards,
> > Jean-Michel.
> Best Regards,
> Hennie Vos
> The Netherlands
>> Hi all,
>> couldn't use a serial mouse into the Stamp and generate the
>> Regards,
>> Jean-Michel.
It's progressing slowly.
The first thing to realise is that a BS2 or BasicX-24 just isn't fast
enough to handle the data stream from a PS/2 device. What I have opted for
at this stage is to use dedicated protocol converters which are available
from USAR (http://www.usar.com/). Once I have my prototype running I'm
then going to write the PS/2 routines in assembler using a 16F84.
At the moment I'm still working on the 240x64 graphic display.
Regards
Jean-Michel.
1) Reading a PS/2 device. There is no doubt the BS2 is not fast enough.
That's why we make the PAK-VI which can read a PS/2 keyboard or mouse,
buffer it, and present it to the BS2 or any micro for that matter.
2) Writing to a PS/2 port. Here I'm not so sure. The PS/2 device generates
the clock and it is not clear to me that the PC won't let you go as slow as
you like (within reason). Therefore, I think the Stamp could fake a PS/2
keyboard or mouse, but I'm not sure. Hmm.... maybe a project of the month in
there.
Al Williams
AWC
* Microcontroller Projects with Basic Stamps:
http://www.al-williams.com/awce/sbook.htm
> From: Jean-Michel Howland [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4daZRlNeQMGqIfkF30-mEk_xLyKQcdMiqMAwcOb8mo7UPb74qU2rlNZo6dxANNu3gPN8d7s]vege@v...[/url
> Sent: Saturday, July 29, 2000 9:58 AM
> To: basicstamps@egroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] Re: BASIC Stamp II & PS/2 mouse - more
> >> Hi all,
> >> Regards,
> >> Jean-Michel.
> opted for
> Regards
> Jean-Michel.
>I think there are two issues here:
Yes I had a look at your chip, unfortunately it only does 1 half of the job
that I need.
>there.
From what I can see, you can send PS/2 from a BS2/BX24 to the PC, however
as I said in my last post, reading from a device such as the mouse,
keyboard or the PC just ain't gunna happen. :-)
Regards
Jean-Michel.
>Regards,
>Al Williams
>AWC
>> From: Jean-Michel Howland [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=W1IzMY1AOsqUrlxnVNfuU-AOAfHxy9HTTfUDJg4E3zkb9bQXU_NEISjiCeuXzKLQlbAOyw]vege@v...[/url
>> >> Hi all,
>> >> Regards,
>> >> Jean-Michel.
>> opted for
>> Regards
>> Jean-Michel.
