Capturing square wave count (OT?)
I am looking for a chip that can capture a square wave - that is count and store the rising or falling side - and store the count until polled(sp?) by a stamp (serial?) at which time it resets to zero and begins the counting process again until polled without losing any data. I need to combine and modify the counts of two square wave inputs and create a square wave output using a stamp for the computation and output generation.
Can anyone recommend a chip/process to do this?
Roger
Roger Edberg
roger@industrialartist.com
http://www.industrialartist.com
Roger
Roger Edberg
It stores the last high duration and the last low duration. It also stores
the total count of edges it sees. Reads 8 channels at the same time with 5uS
resolution. Have a look at http://www.al-williams.com/awce/pak7.htm
Al Williams
AWC
*New: 8 channels of pulse output for servos, PWM, etc.
http://www.al-williams.com/awce/pak8.htm
From: Roger Edberg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Msogy5FfRRoApUZeKISQFZlTg6j_w91XPcPHM_ec-x51NOKGDuMIxHmdJGQok2iSmWq8s6-qMFu_axily_yq3_OPXvdG]postmaster@i...[/url
Sent: Friday, May 26, 2000 7:41 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Capturing square wave count (OT?)
Roger
Roger Edberg
roger@i...
Roger
At 07:51 PM 5/26/00 -0500, you wrote:
>The PAK-VII does this (if I understand you). It does not totalize, however.
>Regards,
>Al Williams
>AWC
>From: Roger Edberg [noparse][[/noparse]mailto[noparse]:p[/noparse]ostmaster@industrialartist.com]
>Hi,
>Roger
>Roger Edberg
Roger Edberg
>Hi,
This sounds like the perfect job for Steve Parkiss' Pulse Machine. Steve
has generously made the code (for Scenix chips) available, along with great
documentation at:
http://home.earthlink.net/~parkiss/
If you don't have a Scenix programmer I'm sure myself (or someone else on
the list) would be happy to do it for you. Actually, Steve may offer
programmed chips himself, I'm not sure.
Best, Duncan
