LED Display
Hi Chris,
I've seen some Boards with many displays where each display has
the driver IC bulit in and there was four lines for BCD and Select
line for each display.
Your board sounds like each display on the board has common
pin to all the digits and you either need to ground that pin or supply
it with 5 volts (don't forget a current limiting resistor) and then you'd
use just one display driver chip for all the displays and select the
display you want with the common pin(as I talked about above).
I hope this helps I'm getting ready to leave and in hurry.
Michael Fowler
C Programmer
Michael Fowler
C Programmer
I am looking for an outdoor led display that I can connect to a·basic stamp.
It needs to be a Single Line, 6 digit display (ie to display: 145.58· )
Readable from 75 -·400 feet (8 - 10" letters), in direct sunlight outdoors.
Thanks for your help
side, "APLUS BT-M405RE". I am trying to interface to the stamp, but
can't find it pin out data. Did a google search with no results. Any
ideas on how I might find the pin out on this thing?
Thanks so much for your help..
Leroy
I found the specifications with the following in google search;
1) search for LED or LED's.
2) then search within results for displays.
3) then search within results for APLUS.
4) this will give you the APLUS home page at the top of the list,
bookmark this site.
5) then use their search to find your part.
Here is the destination that will have your information;
http://www.aplusproducts.com/Leds/LED_Displays/PDF/d-three-type2.pdf
You need to learn on how to do better searches using Google Search.
Have Fun !!
Dale Fleischmann
Leroy Hall wrote:
> I have a seven segment LED display, red digits, 3 characters. On it's
> Leroy
This is a little off topic, but I'm working on a project that needs a
four digit LED Display. I have looked in digikey, mouser, and jameco,
but haven't found the size I need with four digits. Does it matter if I
get four single digit displays and put them right next to each other?
I'm using the max7219 to control it.
-Mike
Note the 7219 chip comes in two flavors,
common anode and common cathode. Your
LED displays MUST be the same kind as
the 7219 you have for it to work.
The 'common anode' means all the anodes
of all the LED's are tied together. To
light one LED, you drive its cathode,
which does have its own pin. This cuts
down on the number of wires.
--- In basicstamps@yahoogroups.com, "Mike Dillon" <laxboy687@e...>
wrote:
> Hey,
a
jameco,
if I
other?
> -Mike
placing them right next to each other. In my experience, using displays from
the same "family" look good right next to each other. I bought these from
Digikey. To interface to them, I have a Maxim ICM7218A (8 digit driver),
using two of the digits of the driver to drive three other dots on the
displays (a ":" and a degree symbol [noparse][[/noparse]that's what I use them for, anyway]).
Using a 74F675 (serial to parallel shift register), I can interface with the
display using only 4 pins of my BS2. I used to be able to use three pins,
combining the functions of loading the output of the shift register with the
loading of the registers in the driver chip (through an inverter), but when
I put an ADC on my breadboard this stopped working (some sort of noise I
guess!).
To send updates to the display driver only required a very short segment of
PBASIC code. I can share it if you want.
Steve
Sent: Tuesday, July 15, 2003 7:48 PM
Subject: [noparse][[/noparse]basicstamps] Led Display
> Hey,
> -Mike
I want to blank single digits from my 6 (well, 8) digit display. These are
common-anode displays. I tried putting a transistor to the anode side of one
digit (again, confusion - "anode" to me means "negative", but the rest of
the world is backwards [noparse]:)[/noparse]... Anyway, the base of the NPN went to a stamp pin
for this test via a 10K resistor, the emitter going to the anode of the LED,
and the collector to the "DIGIT 8" pin of the driver. I noticed that this
digit was much dimmer than the rest, due to the Vce of the transistor I
assume. However, I accomplished blanking of that single digit. The driver IC
only alllows blanking of all or none.
How can I achieve this without too much loss of driver current? If I
remember right, a FET may be able to do a better job. Ideas?
Thanks!
Steve
Sent: Tuesday, July 15, 2003 8:25 PM
Subject: Re: [noparse][[/noparse]basicstamps] Led Display
> I currently use two LTC4624JF 3 digit 7 segment displays to get 6 digits,
from
the
the
when
> guess!).
of
> Steve
> From: "Mike Dillon" <laxboy687@e...>
> > Hey,
> > -Mike
and
2N2906
e c
anode 8 driver -->\___/--- anodes
|b
stamp pin --/\/\----'
1k
The display will be blanked when the Stamp pin is high. And it will
follow the driver when the Stamp pin is low. In this circuit you
will be using the PNP in the common emitter configuration with the
load on the collector, so the voltage drop across the transistor will
be only 0.1 or 0.2 volt. In your other configuration, you had the
NPN transistor connected in common collector (emitter follower)
configuration, and that automatically drops at least 0.7 volt.
You can do the above circuit alternatively with a P-channel logic
level mosfet, with the source connected to the anode driver.
p-ch mosfet
s d
anode 8 driver ---|===|--- anodes
|g
1k
To add more confusion to the souce/sink question, observe that
p-channel mosfets usually have their source connected to the most
positive supply and referenced to flow of (+) charge carriers, while
n-channel mosfets have their source terminal connected to the most
negative supply, referenced to (-) charge carriers.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>Well - I've tried something new today!
>Thanks!
>Steve
to know.
-Mike
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iUYu-vcxETXJzH1KBhF_SeOAbCzqvc8USw9tpQOWvOoNoYoAOZA2LsF6a6MRMgvzKqAsr6k2GDvD4qQ]tracy@e...[/url
Sent: Tuesday, July 15, 2003 4:13 PM
Use a PNP xistor instead of the NPN.
2N2906
e c
|b
1k
p-ch mosfet
s d
|g
1k
-- best regards
Tracy Allen
mailto:tracy@e...
are
of one
of
stamp pin
LED,
this
driver IC
>Thanks!
>Steve
In this case I should use a PNP transistor.
Regards
ECO
Sent: Tuesday, July 15, 2003 9:21 PM
> Thanks!
> Steve
> From: "Steve Ziuchkovski" <zman97211@y...>
> from
> the
> the
> when
> > guess!).
> of
> > Steve
> > > Hey,
> > > -Mike
> and
