Pulsin question
Archiver
Tracy:
Your message said:
The BS2 pulsin command returns a value of zero when it does not detect a
pulse within 65535*2 microseconds (=0.131070 seconds).
I read this in the manual, but its meaning is not clear (at least,to me).
Does this mean that the BS2 times-out as soon as it receives the pulsin
command, or does it mean that it times-out if it doesn't receive the
trailing pulse edge in 0.13 secs? I would hope it is the latter.
Ray McArthur
Ray McArthur
A program cannot become "stuck" at a pulsin command, waiting for a pulse
that never comes. The command execution will terminate within 0.262
seconds with or without a good pulse being detected. A result of zero
means either (1) that a pulse never started, or (2) that it was too long in
duration.
The manual says, "Pulsin waits a maximum of 0.131 seconds for a trigger,
then returns with 0 in resultVariable. If the pulse is longer than 0.131
seconds, Pulsin returns a 0 in resultVariable."
-- Tracy
Thanks for the clarification. I never used the command, and thought the
program would wait as it does for serin.
Ray McArthur
To: <basicstamps@egroups.com>
Sent: Friday, May 26, 2000 1:48 AM
Subject: [noparse][[/noparse]basicstamps] Pulsin question
in
> duration.
pin. The PULSIN command limits me to 52.428 ms. Is there a way around
this or a way to set up something that will allow me to measure a high
signal for up to 1 second?
please help
if high then goto timing loop
then subtract out the cost of the initial and exit time for the -if
Sent: Wednesday, August 29, 2001 1:06 PM
Subject: [noparse][[/noparse]basicstamps] Pulsin Question
> i have a BS2sx and i want to time how long i have a high input on a
> please help
often for the condition of the input? how often, can you set a time limit ( like
ten miliseconds ) to this function?
thanks for your response by the way.
` shawn
> ** Original Subject: RE: [noparse][[/noparse]basicstamps] Pulsin Question
> ** Original Sender: "rad0" <rden25@m...>
> ** Original Date: Wed, 29 Aug 2001 22:35:26 -0400
> ** Original Message follows...
> how about something like
> > please help
End Original Message
>please help
http://www.emesystems.com/BS2speed.htm#longpulse
has some routines that resolve longer (~1 minute) time intervals to
better than one millisecond, using a BS2. Finer by a factor of 2.5
with the BS2sx.
-- Tracy
