Pulsin Command
Following is a sample from my code using the Pulsin command:
(Code Starts Here)
p1 var byte
p2 var byte
tempcheck:
pulsin 5,1,p1
pulsin 5,0,p2
tz1 = 455 - ((720*p1)/p2)
pause 1500
Here is my problem. I am measuring the a pulse comming from a TMP04
Temp. Sensor When I read the High portion (BINARY one(1)) pulse and
the Low Portion (BIN zero(0)) pulse, P1 and P2 always read ZERO (0)
when i display on my LCD or using the debug command.
The lenth of the pulse's at roome temp are as follows
p1 => 18.2ms
p2 => 15.7ms
Can the stamp not read this small of a number or am I doing somthing
wrong?
THanks in advance.
Tobin Moore.
(Code Starts Here)
p1 var byte
p2 var byte
tempcheck:
pulsin 5,1,p1
pulsin 5,0,p2
pause 1500
p1 => 18.2ms
p2 => 15.7ms
wrong?
THanks in advance.
Tobin Moore.
Try making yours variables words instead of bytes.
I don't believe you can represent milliseconds
with just 8-bit variables.
Also I would watch for how my math was done to
avoid a division by zero problem.
Hope this helps,
Bob
>(Code Starts Here)
>p1 var byte
>p2 var byte
>tempcheck:
> pulsin 5,1,p1
> pulsin 5,0,p2
> pause 1500
>p1 => 18.2ms
>p2 => 15.7ms
>wrong?
>THanks in advance.
>Tobin Moore.
The Pulsin command measures time in 2 microsec intervals. This results in a
byte var only good to 510 microsecs: beyond that you get overflow with the
lower 8 bits being 0. Use var word, and you should be good to 0.131 secs.
Good luck,
Ray McArthur
To: <basicstamps@egroups.com>
Sent: Thursday, May 25, 2000 2:32 PM
Subject: [noparse][[/noparse]basicstamps] Pulsin Command
> (Code Starts Here)
> p1 var byte
> p2 var byte
> tempcheck:
> pulsin 5,1,p1
> pulsin 5,0,p2
> pause 1500
> p1 => 18.2ms
> p2 => 15.7ms
> wrong?
> THanks in advance.
> Tobin Moore.
Yes, as Ray & Bob suggested, redefine p1 and p2 as word variables. But I
think there is some other problem. Is the sensor hooked up to P5 (physical
pin 10 on the module?) The BS2 pulsin command returns a value of zero when
it does not detect a pulse within 65535*2 microseconds (=0.131070 seconds).
The expected values of 18.2 and 15.7 milliseconds are well within that
limit. That is why I wonder if it is really hooked to the pin. I surmise
that the pulses are verified by looking at an oscilloscope? Also, are you
sure your LCD code is okay?
Once you do have the pulses, the math is bad. Yes, it is straight out of
the TMP04 data sheet, however, integer math on the Stamp requires that you
keep in mind the limit of 16 bits on word variables. An 18.2 millisecond
pulse gives a count value of p1=9100. When the program calculates 720*9100
will erroneously come up with 63936, which is the mod 2^16 remainder of the
right answer of 6552000. Divide that by p2, and you see strange results.
(Though that does not explain the zero results you are getting.) Post
another message if you need some help on the integer math.
regards,
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
>p1 var byte
>p2 var byte
>tempcheck:
> pulsin 5,1,p1
> pulsin 5,0,p2
> pause 1500
>p1 => 18.2ms
>p2 => 15.7ms
>wrong?
>THanks in advance.
>Tobin Moore.
