Servos
Archiver
Is the pwm/potentiometer system used by the Futaba servos limited to
hobby servos, or are there other manufacturers that will let me use
the same code to operate larger pieces? I am building a gadget for a
quadreplegic friend of mine. I made a mock up using the hobby servos
that is working pretty well, however the end product will require the
servos to be able to rotate a balanced ten pound mass about it's
axis. If servos are not an option is the bs2 compatible with stepper
motors?
motors?
button. Then go to R/C systems and select Tonegawa Industrial Type Servos
The specs for torque are: Starting torque:
Ms 65.33 Kg/cm (907 oz/in) @ 6.0 VDC
91.50 Kg/cm (1271 oz/in) @ 8.4 VDC
Hope that helps if you want to stick with servos.
Tim
[noparse][[/noparse]Denver, CO]
To: <basicstamps@egroups.com>
Sent: Wednesday, May 24, 2000 10:42 AM
Subject: [noparse][[/noparse]basicstamps] Servos
> motors?
http://www.vantec.com/ssps105.htm
World strongest RC Servo.
ACJacques
> motors?
servos, but based on your specs some of these may be overkill. Good quality
(futaba) 1/4 scale servos have torque figures in excess of 200 oz/inch and
can be had fairly cheaply at any local RC model shop. They *are* bigger
than standard servos though. Standard size, hi-torque, metal geared servos
from the big manufacturers (JR, Hitec, Futaba) max out at about 130 oz/inch.
Best, Duncan
standard "hobby servo" PWM see:
http://hometown.aol.com/Ckdesign1/actuator.html
These have a very long life, are very robust, and are very expensive also!
> From: EL-JEFE@P...
> Reply To: basicstamps@egroups.com
> Sent: Wednesday, May 24, 2000 9:42 am
> motors?
code for the Stamp1, but itndon't work on the servo. I don't know if
the servo is defective or if the code won't work.
Any Ideas?
Doug Simpson
isn't working?
-William
Sent: Monday, October 23, 2000 7:44 AM
Subject: [noparse][[/noparse]basicstamps] servos
> I am trying to make a servo work with a Stamp2-SX. I have tried the
> Any Ideas?
> Thanks
> Doug Simpson
whole thing but the servo + line is connected directly to the +on the
battery ahead of the Stamp2SX regulator. The grounds are connected.
And the pulse line is connected through a 1K resistor to the pin on
the Stamp2SX.
The code looks like this:
dirs %0000000000010000
servo:
pulsout 4,150
pause 20
goto servo
This is the same basic code in the manual to control a servo with the
Stamp1. An LED connected to the pulse line glows very dimly, so I
know the pulses are there, I just don't know about the rate, length,
etc.
Thanks.
Doug
> From: "William Cox" <william@c...>
> Date: Mon, 23 Oct 2000 08:10:26 -0400
> Reply-to: basicstamps@egroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] servos
> Are you using two power supplies? Are the grounds connected? What exactly
> isn't working?
> -William
> From: <veewee77@a...>
> > Any Ideas?
> > Thanks
> > Doug Simpson
>Actually, one power supply. It is a 6V gel-cell that powers the
>the Stamp2SX.
>servo:
>pulsout 4,150
>pause 20
>goto servo
>etc.
>Thanks.
>Doug
The Stamp2SX uses different timing values than the Stamp1. In many
cases you cannot use code meant for a Stamp1 with a Stamp2SX, at least
not without some conversion.
In the pulsout command you should be using "1875" in place of "150".
1875 should centre a servo connected to a Stamp2SX.
Jason
__________________________________________________________________
Get your free Australian email account at http://www.start.com.au
>Jason
Jason is EXACTLY right, with the StampI operating at 4MHz, the StampII
operating at 20MHz and the StampII-SX operating at 50MHz ALL of the
timing functions will be different.
The values below correspond to a "Center" position with each Stamp.
Stamp1 = 150
Stamp2 = 750
Stamp2-SX = 1875
Conversion Table:
Stamp1 --> Stamp2 multiply by 5
Stamp1 --> Stamp2-SX multiply by 12.5
Stamp2 --> Stamp1 divide by 5
Stamp2 --> Stamp2-SX multiply by 2.5
Stamp2-SX --> Stamp1 divide by 12.5
Stamp2-SX --> Stamp2 divide by 2.5
Beau Schwabe IC Mask Designer
National Semiconductor Network Products Division
500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
least
"150".
>>Jason
StampII
I'm don't think ALL the timing functions are different between the
stamps. I suggest anyone who is using the SX should go to
www.parallaxinc.com and download both the StampII as well as the
StamIISX addendum manuals.
Quote from the stampSX addendum manual:
"Of the 39 BS2-SX commands available, 3 are new, 25 are
identical in function as with the BS2, and 11 vary from the BS2-IC
only in their timing."
With regards to the coding used for the servo(by Doug I think), the
PULSOUT command uses differing timing depending on which stamp you
have. But the PAUSE has the same timing units on both BS2 and BSSX.
Jason
How do you guys attach servos under the base of your robot?
Nicolas
-William
Sent: Tuesday, November 28, 2000 9:03 PM
> Just a practical question:
> Nicolas
You can use dubbelsided tape or wirestraps, or both.
Maybe glue them on the base?
But the best way is probably to bolt them on that way they do not move at all.
Regards Ken J
Sent: Wednesday, November 29, 2000 3:03 AM
> Nicolas
Ive tried double sided tape and they tend to wobble about.
The little clamps you get from model shops dont seem to fit all Servos.
The best ive done so far on my last platform was to use a couple of
posts and stretch a piece of aluminium across them to clamp them on.
My servos were back to back so I also taped them together with insulating
tape so they were properly lined up.
Now if only I could glue the wheels on to the servo arms straight, I could
get it to go in a straight line.
Gordon
From: Nicolas Fournel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pp6VlnpZzssDuednOQ7ZfGB2KkeoRcEQNthuhYMUGNxtJNjT6uDBREsDc71LHEkBYZEldBWc4ydBfWF-STPeg62p]Nicolas.Fournel@f...[/url
Sent: 29 November 2000 02:04
Nicolas
>With difficulty.
>Gordon
>Hi Gordon -
>If the wheels have solid hubs (not spoked) why not SCREW them, not GLUE
>them ? That would seem to provide a firmer foundation.
Bruce Bates
I have used double-sided tape before as well, but wasn't too happy with
the results. You might want to try this web site http://www.servocity.com/
They carry servo mounts, gears & sprockets that are molded to fit
directly onto the servo output shafts, and chains to build tracked
robotic vehicles. For just a couple bucks -- you can have everything
you need to put together some really solid servo platforms.
Hope this helps...
Bruce
webmaster@r...
Sent: Friday, December 01, 2000 3:05 AM
Subject: RE: [noparse][[/noparse]basicstamps] Servos
> With difficulty.
> Gordon
> From: Nicolas Fournel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GA18pl3eTTXwMNZlz9tJVwc7RrwX5BbORTdH_XOAkrb5VNM0A5e3-SYQ9ckOxStOUcNqYt3ptHFxdd7AbasMhv1WvOHyyQ]Nicolas.Fournel@f...[/url
> Nicolas
Ive had a bit of trouble finding good wheels.
What Ive found so far are some nice balloon tyres from R/C plane landing
gear.
They have aluminium centres. But the centres are domed.
I found some nice wheels at B&Q last weekend. nice size and a nice tyre on
them.
But it was designed to go on a spindle and didnt have a surface at all on
the inside.
So i built up the hollow spindle with lots of hot glue and managed to
balance one of the
round servo actuators on the hollow spindle for the best result so far.
Where do you get your wheels ?
Im also having trouble getting an IR proximity detector.
Ive tried Totalrobots, milford instruments and technology information
exchange.
There dont seem to be any kits in the UK at the moment.
I would have a go a making one from scratch but im no electronic engineer
and cant
find a set of idiot instructions that dont require scopes and other "Expert"
knowledge.
Gordon Endersby
A Newbie without enough electronics knowledge.
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9pg7pafJdC75GM2_ri41_RF8peRKmgo-RJI2fUY0COYsippqYE-PCmziO5f4y_itV7tENooSWcn4Lxp0Vyw]bvbates@u...[/url
Sent: 01 December 2000 10:22
At 05:05 AM Friday 12/1/2000 -0500, you wrote:
>With difficulty.
>Gordon
>Hi Gordon -
Bruce Bates
>Hi Bruce
>DuBro has the BEST wheels I've seen NEW, but there are MANY surplus
>resources, at least here in the US.
>What Ive found so far are some nice balloon tyres from R/C plane landing gear.
>them.
>the inside. So i built up the hollow spindle with lots of hot glue and
>managed to balance one of the round servo actuators on the hollow spindle
>DuBro has "super strength" actuator arms which you can assemble as you see
>fit :
>[noparse][[/noparse] http://www.probuild-uk.co.uk/products/servo_arms.php3 ]
>Where do you get your wheels ? DuBro, naturally, via Tower Hobbies [noparse][[/noparse]
>http://www.towerhobbies.com ] : ) Yours can be obtained directly from [noparse][[/noparse]
>http://www.probuild-uk.co.uk/index.php3 ] ! You may be looking in the
>wrong places.
>exchange.
These additional references SHOULD help : )
>and cant find a set of idiot instructions that dont require scopes and
>other "Expert" knowledge.
>Bruce Reynold's FireStick is the BEST Ir tx rx setup that can be had [noparse][[/noparse]
>http://www.rentron.com ]. That's one method, and other method, which has
>the additional advantage of measuring the actual distance is the IRODS
>sensor which can be obtained from [noparse][[/noparse] http://www.hvwtech.com/sensors ].
I hope that gets you going in a better direction.
>Gordon Endersby
Bruce Bates
More bookmarks then
he OUGHT to have !
Not my bank balance though [noparse]:)[/noparse]
Gordon
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4bWmx9fTmr6HMLZKpoWr4DreQunm3mphAPNyW24q8f1FDN7oEXppTmQ0eHyPy3SHXthGzx92kvR7cq_6og]bvbates@u...[/url
Sent: 01 December 2000 13:36
At 05:29 AM Friday 12/1/2000 -0500, you wrote:
>Hi Bruce
gear.
>them.
>fit :
>wrong places.
>exchange.
>Gordon Endersby
Bruce Bates
More bookmarks then
he OUGHT to have !
powering my servos on a loaded circuit. I have a 5 sensor array
breadboarded and I'm powering it with a 9V battery going through a
5V regulator and all is well. Most of the articles and basic lessons
on this kinda "robot" use a 9V feeding the stamp and detectors, and
4x1.5AA to run the servos, is this the norm or can you use the same
supply voltage,maybe 2x9V in paralell going through the
regulator,and some kinda motor driver ie. H bridge?
