BS2&68HC11 again
That depends greatly on the application. The BS2 can indeed work in many
cases where the 68HC11 would be used. However, if you want to use
interrupts, expanded-mode memory, or A/D conversion, the Stamp will require
clever design or external circuits to do the same thing.
On the other hand, the 68HC11 needs a power up reset controller, a crystal,
and a regulated power supply. The Stamp needs none of these things. There is
a basic compiler for the HC11 (SBasic) but it does not have many of the
high-level commands that PBasic has (like PWM, for example).
If you can be more specific about what you want to do with the Stamp, many
people here will be glad to give you ideas about how to do it with a Stamp.
Al Williams
AWC
* Expand your Stamp I/O: http://www.al-williams.com/awce/pak3.htm
> From: Mohamed REFKY [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dsIyb7zurObLNhbkjZYM_5GIzFqs_2ccEK4EHb72VI7VSVre-O1fu-Z4MURQSPPtEVuDzPj-Uw]refky@h...[/url
> Sent: Tuesday, May 23, 2000 4:56 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] BS2&68HC11 again
> Hello group,
> Because I did not receive answer before,I repeat my question:
> Can the BS2 be used instead of 68HC11 microcontroller.
> Thank You
> Mohamed Refky
> ________________________________________________________________________
> Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
Al Williams
AWC
> Hello group,
> Thank You
> Mohamed Refky
Thank You
Mohamed Refky
