Can''t find hardware
Of the cuff, are you sure nothing else is using that serial port the BS2
is connected?? Also, did you connect pin6 and 7 together at the end of
your serial cable?? I'm going from memory on this one, verify it in the
BS2 manual. Other than that, you may have to research how PocketDOS
handles the serial port.
HTH
.mark
Mark Schoonover KA6WKE IS Manager
Trail Runner,HAM schoon@a...
ka6wke@wb6dgr.#sca.ca.usa.noam
http://www.qsl.net/ka6wke ka6wke-1 145.05
Mobile: 146.52 & 28.470
Lat: 32.85380 Long: -117.00980 Grid: DM12LU
>From: Don DeGregori[noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AUxEygYNSURpNJJ011cjwtRnWFU29K-b7d23e8HI3JEwEJClBWUocW3cgnqGa9quzVpS2521fzyarw]don1mh@l...[/url
>Sent: Friday, May 19, 2000 8:47 AM
>To: basicstamps@egroups.com
>Subject: [noparse][[/noparse]basicstamps] Re: Can't find hardware
>--- In basicstamps@egroups.com, "Don DeGregori" <don1mh@l...> wrote:
>> Has anyone tried to interface a Basic Stamp II to a CE computer?
>> Don
>I'll expand a bit I have a NEC MobilePro 750C with a serial port, but
>needs a null modem adapter to connect to a modem. I have a shareware
>program called PocketDOS and it is on the NEC. I installed
>stamp2.exe,
>too. No problem, both work OK. I configured COM1 as per instructions
>from PocketDOS. I hooked it up to the stamp. But, always get the
>"can't find hardware" message. The stamp works fine on my regular PC.
>Any idea appreciated. Don
HTH
.mark
>> Don
>stamp2.exe,
